View unanswered posts | View active topics It is currently May 1st, 2026, 2:52 pm
Reply to topic  [ 27 posts ]  Go to page 1, 2, 3  Next
 Engine breather
Post Engine breather
I took apart the breather on my car this week, just out of idle curiosity as I've never opened one up before really, but I'm guessing it's been on my car since it was new and I've suspected it's not been in tip top condition for a while...
It fills up with emulsion almost weekly, no idea why as the car gets thrashed over a fairly long distance twice a day.
I ground around the lip halfway down the breather to release the two halves...
With the top removed you're left with this bit. It's pressed into a rubber gasket and the bottom half of the breather. Gently prising it out with a screwdriver revealed this rubber one-way valve...
In this breather the rubber had perished and there was 1/3rd of the rubber broken away completely, obviously this should have (and I dare say *will*) be what consigns this breather to the dustbin. Only once I'd got this far did I really check how much they are new. This, perhaps, I should have done first. Then followed an hour long search of the farm for a bit of thin rubber to match the broken valve. I eventually found a suitable bit of rubber and cut it into a circle using the broken one as a template. I secured it to the three original securing holes (originally it had three rubber pegs, but these were also buggered) with three pop rivets.
The bottom part of the breather also has a different type of one-way valve built into it, it's a piece of rubber tube with slots cut into it, which sleeves over a metal pipe with perforated holes behind the rubber slots. Air can come up from the crankcase through the metal pipe and out through the rubber slots, but the slots will close up and seal if air tries to go the other way. I didn't have any rubber tube and having already come unstuck having to hunt for a bit of rubber sheet for the other valve (I used a mudflap off me 2CV, BTW) I elected not to try and replace it and I cleaned up up as best I could and left it. It wasn't broken like the other one.
Then I welded the two halves back together (minus the rubber gasket, I'm not sure how critical it was, but I assume becaue the breather originally fitted together with a rolled seam it needed a gasket, it's welded now, and therefore sealed) You're best off cleaning it right up and fusing it with a TIG welder, but you're welcome to MIG it like I did, it just doesn't look very nice. It's important not to put too much heat into it because you'll bollocks the rubber you just replaced again. Don't bother gas welding it or brazing it, the rubber is almost immediately behind the bit you're welding, and the heat will shag it.
Then I stuck it back on the engine. Does it work? I do not know, but I hope so, I can't see why with all the oil residue and mayo and shite removed, and that broken rubber one-way valve replaced, it shouldn't at least be an improvement on what I had. The worst case scenario is that I need to buy a new one, and I'd have had to do that anyway, so it was worth a try. I'll report back when I've finally finished putting this cocking engine back together...
March 30th, 2011, 11:38 pm
Post Re: Engine breather
You can leave it as is and fit one of these .
http://www.ecas2cvparts.co.uk/valve-cra ... 5606d0010e
Probably available from other suppliers too !! :roll:
March 31st, 2011, 12:06 am
You could Norman, but it's over £40, and if I've rescued it with a bit of rubber that cost me nothing then I reckon I've done alright. It's actually very simple when you've got it apart. It's a great shame that Citroën made it sealed unlike the early cars which were serviceable. I also prefer using a standard breather to one of those cpd valves, although not for any rational reason...
March 31st, 2011, 12:13 am
Did you use oil resistance rubber?
http://www.pp-2cv.be/FR/News/info%20tec ... ard%20.htm
March 31st, 2011, 11:28 am
I dont know, are 2cv mudflaps oil resistant?
March 31st, 2011, 11:40 am
:lol: don't think so
March 31st, 2011, 11:44 am
Russ has been pointed in the right direction ;)
March 31st, 2011, 1:31 pm
I should point out i was well aware that what i used probably wont last very long, but i had nothing else at the time and if it works for a couple of weeks then all is well. As Sean has suggested an ideal source of new valves i'll probably cut another breather up in the near future and do that instead. I just thought the photos and principles might help others, half an hours work saves over £100 replacing the whole thing.
March 31st, 2011, 2:28 pm
PP in Belgium has a repair part just for the thing you did, take a look at it.....
http://www.pp-2cv.be/FR/News/kit%20repa ... flard.html
but it is 70 euro's..............
March 31st, 2011, 4:54 pm
RE PP-2CV in Belguim.
Has anybody in the UK purchased from this guy (Andre Jaques).
My requests are completely ignored??
March 31st, 2011, 5:07 pm
Users browsing this forum: No registered users and 73 guests
