View unanswered posts | View active topics It is currently May 1st, 2026, 2:52 pm
Reply to topic  [ 7 posts ]
 Headlamp shell removal/refitting
gym bunny
Post Headlamp shell removal/refitting
Anyone got a good way to remove them without knackering up the nut or shell? So far I have had to cut the rusty blob of nut off any I have done in the past.
Anyone bought any new plastic ones from ecas or other suppliers? Do you get the cup washers and nut and bolt etc with them? Are the plastic ones any good?
Attempted to return to the garage after work, after the grinder incident but it didn't go so great, knocked the scar on my finger and OMG it hurt! Back to the PC and TV it is.... :cry:
Tim
1299cc FTW
March 29th, 2011, 5:21 pm
Post Re: Headlamp shell removal/refitting
if its a metal shell give the nut some heat and diesel/plusgas/release oil
March 29th, 2011, 5:35 pm
gym bunny
I tried that approach but the bolt head inside the shell always seems to turn and knarl things up, more so on the plastic ones.
1299cc FTW
March 29th, 2011, 6:57 pm
Is there something you've forgotten to tell us, Timmy?
March 29th, 2011, 7:39 pm
gym bunny
Happened 13th February.... grinder with 1mm cutting disc caught and I got in the way as it carried on! :shock: Picture from 2 days after the accident!
Must wear gloves when I return to using it although to be honest I don't think it would have made much difference, only more pain when trying to remove the glove to find out if the finger is still attached!
1299cc FTW
March 29th, 2011, 8:04 pm
<wince>
You _stupid_ boy...
Some St Val pressie for SJ...
March 29th, 2011, 8:20 pm
Tim,
the way I've tackled this problem is with the light bar upside down, drill some holes, each 1/8" diameter and situated right on the edge between the bolt and the nut.
Try drilling 4 first, fill the holes with penetrating fluid and leave overnight before attempting to undo the nut.
Even with part of the thread on the bolt missing, there's still enough grip when new (nyloc) nuts are fitted, with plenty of coppaslip for good measure... ;)
( Almost forgot, don't cut the wiring loom or destroy the socket, as it's possible to push back the locking tabs and remove the wires complete with their terminals.
I hate it when you go to change a headlamp bulb and the terminals are fitted 'bare' or there's a mess of chocolate block connectors inside the shell. :roll: )
March 29th, 2011, 8:35 pm
Users browsing this forum: No registered users and 73 guests
