Reply to topic  [ 5 posts ]
 Front wheel bearing replacement
Post Front wheel bearing replacement
Do I need the proper tool to replace front wheel bearings, or is there a less expensive way to do it?
Thanks! Ben
March 23rd, 2011, 10:57 pm
Post Re: Front wheel bearing replacement
Ben,
you can drill through the bearing retaining ring at the 'notches' where the removal/fitting tool engages.
Start with a 5mm drill bit and work upwards in size until the halves of the ring can be collapsed inwards.
When refitting, get some 1/4" square bar and cut it down so that it fits across between the notches, then tap that round with a drift.
Try and avoid using the punch directly on the retaining ring, as that could damage the threads in the hub carrier.
( Note that it would be preferable to use the correct tool, however. ;) )
Thanks! Ben
March 23rd, 2011, 11:18 pm
Somewhere or other I did a quick write up on how to do it with the tool, I think it is in Russ's red spesh thread. It is easier with the tool.
March 24th, 2011, 12:14 am
Here:
viewtopic.php?f=5&t=1831&start=230
March 24th, 2011, 12:18 am
Thanks very much all! Looks like the tool might be the easier route :)
March 24th, 2011, 10:48 pm
