View unanswered posts | View active topics It is currently May 1st, 2026, 2:52 pm
 Changing brake fluid
Post Changing brake fluid
Wanted to read up on this tonight but I've left my haynes manual at the barn with the van.
Please tell me its as simple as draining out the old fluid and putting new stuff in, then bleeding the system?
Any hot tips?
March 7th, 2011, 12:35 am
Post Re: Changing brake fluid
Any hot tips?
if you drain the system its worth priming the master by bleeding it out at the unions on the cylinder first then bleed the brakes in the normal way through the nipples at the brakes.
I just open the rears and pump a resevoir almost empty top with clean and pump that through then do the same on the fronts.
March 7th, 2011, 12:55 am
Do I need to get somebody to open/close the bleed nipple as I pump the break as suggested here: http://www.ehow.com/how_2111457_change-cars-brake-fluid.html
Or can i literally open the nipples and pump?
March 14th, 2011, 1:07 am
sam
here you go...
< http://www.google.co.uk/imgres?imgurl=h ... 29,r:2,s:0 >
Don't forget to tie a knot in the b@gg#r, as a reminder how to spell 'brake'... :roll:
March 14th, 2011, 2:05 am
Sam
one of these helps.
March 14th, 2011, 9:20 am
The risk is that one person can't see when all the air is out or not. It is a 2 people operation.
March 14th, 2011, 9:41 am
no its not :P
And how can the assistant see the bubbles in a steel pipe anyway? ;)
Use that little gizmo, you can usually position the lot so you can operate the break(sic) pedal by hand while peering under the car to see what's happening at the rear.
Its really efficient hook it up, open nipple pump 1/2 a resevoir through, close nipple, repeat at other rear ( needs less fluid through this time as you are only flushing the cylinder and the pipe from the T piece), then do front.
You end up with a rock solid pedal and a flushed system. And no waiting for the glamorous assistant to find her shoes and put on some old jeans etc :lol:
March 14th, 2011, 10:10 am
Sean wrote:
no its not :P
Its really efficient hook it up, open nipple pump 1/2 a resevoir through, close nipple, repeat at other rear, then do front.
I use a clear plastic tube so I can see the air going through it. When no more air I close the bleed-screw. My (nacked) lady pumps the pedal looking for a hardy. When hard, she holds the pressure, I open the bleed-screw and maybe more tiny air bubble comes out.
March 14th, 2011, 10:17 am
Clearly its colder up here.
March 14th, 2011, 10:50 am
Get a Gunsons easy bleed, they're cheap and effective. It uses a tyre to force brake fluid through the system. The danger of using the pedal to bleed an old system is that you wreck the seals in the master cylinder; an easy bleed is a lot cheaper than a master.
http://cgi.ebay.co.uk/Gunsons-Eezibleed ... 4aa9399187
March 14th, 2011, 11:06 am
Users browsing this forum: No registered users and 73 guests
