Starting trouble!
http://international2cvfriends.com/forum/viewtopic.php?f=7&t=276
Page 1 of 2
Author:  Steven [ April 15th, 2009, 3:02 pm ]
Post subject:  Starting trouble!
Hi Friends,
Now, this happens to me all the time. If I do not start my car for more than a week, she doesn't start. Finally, the engine goes rich, and the spark plug needs to be removed and cleaned. This usually happens only on one cylinder.
I have changed the ignition to new electronic ignition
I have changed the plugs
I have changed the coil.
The only thing I haven't changed are the HT leads. Do these leads lead to serious problems, literally?
Thanks and regards,
Steve
Author:  Russell [ April 15th, 2009, 6:53 pm ]
Post subject:  Re: Starting trouble!
I am no expert, but, if it's only after leaving it for a week I'd suspect the battery is shot. Will it start when jumped from another car? Try charging the battery up before you start it next time and see if that's the cause. I think you can get a situation whereby the starter robs all the power from the coil, so it'll spin over fine but won't actually fire.
Author:  Steven [ April 16th, 2009, 3:13 am ]
Thanks, Russell!
I have, many times charged up the battery and then gone about starting the car, but I have the same problem. Once she is started up, and if I keep her started every other day, then there is not much of a problem. It is only after the time lag...
Regards,
Steve
Author:  toomany2cvs [ April 16th, 2009, 9:01 am ]
You can - especially with electronic ignition - but this doesn't sound like it.
Odd as it sounds, it could be the fuel pump. I've certainly had 'em where the non-return's gone south and over time the pump's drained dry back to the tank.
Author:  Steven [ April 16th, 2009, 4:34 pm ]
Hi!
I had earlier written a post about my faulty fuel pump, which does not pump effectively while the engine is heated (vapour lock?).
In this case, seems like it is pumping initially, since the engine is getting rich. That's why I had not suspected the fuel pump. But if you feel it is the fuel pump, then fuel pump it could be....
Steve
Author:  c-diddy [ April 26th, 2009, 8:19 pm ]
Try putting damp start straight into the carb?
Has the 123 been put on correctly? did it not start when you had points?
Author:  Sean [ April 26th, 2009, 9:01 pm ]
Steven wrote:
Hi!
Steve
"Vapour lock" is a myth with the 2cv
if you have not replaced the rubber parts of the fuel pipe they may well have become brittle and cracked allowing the pump to draw air
or you have an old coil
Presume that all the electric leads between battery and starter are good and the ignition contact drum ok?
as its only one cylinder id look at tappets too
proper "bougicords" seem to last for ever
Finally the only on one Cyl sounds like a problem people were having when their 123 was dying
how is it with NEW points and cond?
Oh Bangalore! whats the quality of the fuel like what is ambient temp? if its up in the +40*c it certainly wont need choke and starting is dip clutch dont touch the gas and churn away for ages untill it falters to life
Author:  Steven [ April 27th, 2009, 4:23 pm ]
Hi Sean,
Thanks for your response. My 123 ignition is brand new, and I changed it because I was having problems with my old points on, too.
In Bangalore, we use unleaded petrol. The temperature does not go above 40*. Bangalore has rather good weather, maximising during the hottest summer to about 35*C.
Thanks again,
Regards,
Steve.
Author:  Daffy Duck [ April 29th, 2009, 1:50 pm ]
If you get down to the stage of needing to replace the HT leads or coil, I would suggest getting a Harley coil from ECAS, which comes with the best HT leads you could wish for. The HT leads are just the right size, which means they go straight from the coil to the spark plugs, over the cylinder, NOT near the headlight frame or mudguard (ie not near ANY metal). That should solve coil/HT problems for a very long time.
Daffy Duck
Author:  Sean [ April 29th, 2009, 7:44 pm ]
Daffy Duck
Hype! a good Argy wound coil and bougichords will give years of service as long as you dont leave the ignition on all night :oops: A yellow coil wont solve any underlying timing tappet or compression issues
trouble is many people are trundling round on a coil that is at least 20 odd years old
