View unanswered posts | View active topics It is currently April 29th, 2026, 11:17 pm
 increase mpg
Post increase mpg
now im aware that the 2cv isnt too bad on fuel, but i do quite a few miles in the old beast, and any increase on the range out of a tank would be a bonus!
seeing as a tank can last me as little as 2 days sometimes!
is there anything such a fititng dyane gear box, heavy / light flywheel that would improve it?
i know a perfectly set up ignition system will give peak performance, to which i need to check the points and timing asap, when i get a chance,
i know mods like fitting a dyane gear box is going to cost more than ill save over a long period of time, but at the end of the day id have a spare box anyway!
i know weve touched on this subject before, but any suggestions would be greatful
February 19th, 2011, 10:29 am
Post Re: increase mpg
take it easy with the right foot.
see if you can drive your route without using your brakes!
dont use full throttle.
dont drive it like its a PS3 Xbox etc
February 19th, 2011, 11:04 am
A light right foot and good road sense to minimize the use of brakes is probably the most effective. That's assuming, of course that the car is in good order.
You beat me to it Sean!
John Jordan
February 19th, 2011, 11:06 am
Interesting... I use my brakes a LOT... but never with the engine in gear, ie, I 'freewheel' a lot. I could never get my head round the idea of having the car in gear when I break... it seems counter productive.
February 19th, 2011, 11:31 am
Nooooo ... the engine should be used to slow down as much as to speed up. You'd fail a driving test for doing what you describe.
Oh, and it's "brake".
February 19th, 2011, 11:51 am
The accelerator pedal uses fuel.
The brake pedal wastes fuel.
February 19th, 2011, 12:17 pm
Give him a break about the brakes. ;)
February 19th, 2011, 12:20 pm
Perfectly put. James may have been influenced by my talk of heavy flywheels etc but the fact is such added hardware doesn't reduce fuel consumption itself, but encourages a driving style that will. Therefore it's not the flywheel or the gearbox that will save lots of petrol, the only component that has the ability to do so is the nut behind the wheel. :D
February 19th, 2011, 12:25 pm
:!: perfect! ... momentum, and the mainteance thereof, is all!
February 19th, 2011, 12:26 pm
Stop worrying about being Eco and plant your foot!!!!
February 19th, 2011, 2:42 pm
