View unanswered posts | View active topics It is currently April 29th, 2026, 8:35 pm
Reply to topic  [ 8 posts ]
 Bleary eyed hub bearing question
Post Bleary eyed hub bearing question
I am half way through a king pin change (4 hours to cut welded in welch plug out and remove other seized things :evil: , ten minutes to remove pin and bushes :| )
While i've got the hub in the vice i can 'waggle' the back plate a bit ,is this normal or does it indicate bearing failure? It doesn't squeal or rumble in use.
February 26th, 2011, 12:17 am
Post Re: Bleary eyed hub bearing question
There will be a bit of play with the drive shaft out. If it was quiet it's likely OK.
February 26th, 2011, 12:23 am
Cheers. with everything else going wrong tonight i started to expect it to be shot as well :D
February 26th, 2011, 12:24 am
Ben,
that play happens because the inner bearing races are clamped together by the driveshaft nut.
Once it's no longer holding them, they will move apart, especially if a fair sized hammer is being wielded close by. :lol:
I guess you had to separate the hub carrier from the track rod end to clean up that mess on the Welch plug area, but normally I find it's not necessary to remove it.
It's not difficult to tap the old bushes out and the new ones in with the hub carrier held in your hand... ;)
http://www.flickr.com/photos/30132857@N06/3617046904/
February 26th, 2011, 12:42 am
Don't forget the king pin is handed when you put it in!
February 26th, 2011, 12:46 am
Took some separating from the track rod end ,it was very attached. Your pic makes things look quicker ,i didn't think of that ,comes with experience i suppose :mrgreen:
I'm following the kingpin sticky thread as i've never done this job before ,so 250 when you say handed i take you mean the way the holes have to line up..
February 26th, 2011, 9:56 am
All done ,all nice..no more kingpins jobs taken to a garage :)
Was in despair at one point, once the tension built up at work this week had worn off on the hammer and still the welch plug wouldnt budge :P
Thanks for replies.
February 26th, 2011, 3:48 pm
It's very satisfying knowing you can do it yourself. I too had movement in the hub, but once the driveshaft was back on the movement went.
February 27th, 2011, 10:28 am
Users browsing this forum: Taskos and 47 guests
