View unanswered posts | View active topics It is currently April 29th, 2026, 4:16 pm
 Fan Pulley Bolt Size?
Post Fan Pulley Bolt Size?
Doh! I didn't tighten it up properly when I had the fan off and lost it in transit somewhere! :oops:
What size is it? I know its got a 14mm head.... but length, M size and thread pitch?
February 9th, 2011, 2:19 am
Post Re: Fan Pulley Bolt Size?
The thread is a standard M10x1.5 and the thread's 35mm long, however if you go and find one off the shelf somewhere it'll have a 17mm head, and you wont fit the socket down the middle off the fan.
You'll need to either find an original, or try one with a socket head (allen key).
February 9th, 2011, 2:42 am
I'd Guestimated M10 and about 40 mil.... hmm! can't just pop down Screwfix and get one! :? and not listed on ecas! :?
February 9th, 2011, 2:52 am
I thought it was some total odd ball size like M9!! Sure Ecas used to list an allen headed one to do the job.
February 9th, 2011, 2:55 am
40mm should be OK, but don't forget the lock washer...
...and maybe a key to drive the bolt?
< http://cgi.ebay.co.uk/FRANKLIN-100mm-LO ... 1382wt_698 >
( As a stop gap, maybe you could use a longer 10mm bolt with a washer bearing on the starter dog to stop the fan escaping? )
February 9th, 2011, 2:57 am
I;m sure I've got a one somewhere in my shed of spare bits but that's at my M & Ds across town... just on the edge of overheating distance! :roll:
February 9th, 2011, 3:02 am
Lock washers no prob... got a stack of them.... shall be looking for a long bolt in the mornin' ;)
February 9th, 2011, 3:14 am
imothepixie wrote:
Joolz wrote:
...and not listed on ecas! :?
Don't let that put you off. Always worth giving Roy a call as he does usually have a stash of unlisted parts.
Also, 2CV City currently list one, part number EP044 @ £2.
February 9th, 2011, 10:04 am
Perhaps too late now but anM10 allen head screw will be easier to find "on the street"ie hardware stores BnQ etc just remember you need to carry the suitable tool for un doing it
February 9th, 2011, 10:21 am
I should post an update with 'my' solution......
I got a 100mm bolt (plenty of length to clear the dog with the a 17mm head) and used a bit of thread lock on a nut at about 35mm along, not elegant, but it got me where i needed to go! :D and a proper bolt!
Unfortunatly... I must have damaged the fan belt, it shreaded to strings round-a-bout today.... oh well fan off again! :roll:
BTW the allen head screws in the diy shops I looked in only went up to M8 :(
February 12th, 2011, 12:12 am
