Reply to topic  [ 5 posts ]
 Computer says... YES! Fan and alternator says... NO!
Post Computer says... YES! Fan and alternator says... NO!
My fan belt got a bit mangled so I immediately went down to the cornershop motor factors.... Didn't have one in so I ordered one up (as a spare!)
Went down to the slightly more warehouse spares place, they have one suitable for a 2cv... something called a 'Gates 6210MC'... but... even with the alternator pushed down as far as it will go, it's still about a belts width to small to go on... I swapped it for the next size up (Gates) which fitted fine! :roll: (there is also scope to move the alternator up to take the slack off slightly larger belts as well surely?)
Well! I got my 'cornershop' belt today and it's another 'Gates 6210MC' :shock: :roll:
Gates 6210MC AVX10 x 750la (if that means summat to sum one!) is not quite right if you want to stick that in your xml database! :ugeek:
February 16th, 2011, 3:35 am
Post Re: Computer says... YES! Fan and alternator says... NO!
You dont have one of the last rubber pulley fans do you? you need the bigger belt
i used to know what size it was off by heart but now i have to write stuff down.
then spend days trying to find "that" bit of paper :?
February 16th, 2011, 10:18 am
No it's a metal one.... Haven't had this problem with other off the shelf belts!
I just think there is a too small one in the 'system', Having just read off other manufacturer's lists! :?
Last edited by imothepixie on February 16th, 2011, 2:33 pm, edited 1 time in total.
February 16th, 2011, 1:52 pm
I'd heard that cars built in the last year or two, ('89, '90), used a different sized(bigger?) belt because one of the pulleys was different. And have in the past been sold a belt that was slightly too small. However my car's an '88 and both pulleys look normal.
Does any one have a picture, or accurate description, of a late type, bigger pulley, so that my vague idea could become a bit of definite knowledge.
February 16th, 2011, 2:29 pm
Joolz,
the rubber mounted pulleys are very easy to spot.
My guess is that Citroen had finally acknowledged there was a problem with the 'spun' fan pulleys and decided to isolate the metal part of the pulley from high speed vibration of the crankshaft.
I bid 763mm for belt length to suit those pulleys.
p.s. @ imo,
You don't happen to have a replacement Iskra type alternator fitted, by any chance?
On some of those, the driven pulley diameter is larger than on the original versions.
February 16th, 2011, 3:22 pm
