| Clutch cable adjuster thread http://international2cvfriends.com/forum/viewtopic.php?f=7&t=2642 |
Page 1 of 2 |
| Author: | Rhythm Thief [ January 28th, 2011, 7:16 pm ] |
| Post subject: | Clutch cable adjuster thread |
Anyone know what thread the adjuster barrel on the clutch cable is? |
| Author: | james2cv [ January 28th, 2011, 7:47 pm ] |
| Post subject: | Re: Clutch cable adjuster thread |
Might be completely wrong but I think one is 22mm the other 19? |
| Author: | Rhythm Thief [ January 28th, 2011, 7:49 pm ] |
You are wrong - they're 19mm and 16mm - and it's the thread I'm after, not the spanner size. But thanks anyway. |
| Author: | james2cv [ January 28th, 2011, 8:00 pm ] |
LOL. This is what happens when you know literally feck all about anything vaguely mechanical, and then think you actually do. |
| Author: | Sean [ January 28th, 2011, 9:14 pm ] |
M12x 1.0 I think |
| Author: | ken [ January 28th, 2011, 10:27 pm ] |
That's the one... Are you in need of a nut, RT? Sean wrote: M12x 1.0 I think |
| Author: | Rhythm Thief [ January 29th, 2011, 12:10 pm ] |
Yes, sort of ... wot I'm trying to do is extend the adjuster barrel because it's the easiest way of extending the cable outer to make an Ami 8 cable fit an Ami 6 with the old type pedal assembly. I've done this by cutting an adjusted off an old cable, but now I need some kind of arrangement to hold it all together. ... I'll post some pictures when I get chance. They're so much better than words. |
| Author: | Rhythm Thief [ January 29th, 2011, 12:18 pm ] |
I suppose I should really have titled this "clutch cable adjuster thread thread". |
| Author: | Russell [ January 29th, 2011, 12:19 pm ] |
I reckon you may be best off buying an Ami8 pedal box. You'd be able to do away with that wafty crank thing I made for the throttle linkage too. Not sure if the master cylinder would fit though. |
| Author: | Sean [ January 29th, 2011, 3:24 pm ] |
Rhythm Thief wrote: Yes, sort of ... wot I'm trying to do is extend the adjuster barrel because it's the easiest way of extending the cable outer to make an Ami 8 cable fit an Ami 6 with the old type pedal assembly. I've done this by cutting an adjusted off an old cable, but now I need some kind of arrangement to hold it all together. ... I'll post some pictures when I get chance. They're so much better than words. weld a gearbox mount spacer on the bulkhead or just use cable tension to keep it there? adjust by adding some seatbelt anchor spacers? Sean |
