Reply to topic  [ 2 posts ]
 Wiring in an oil pressure light
Post Wiring in an oil pressure light
As some of you know, I've got Russ's old Ami 6. Originally it had an M4 engine in it, but now it's got a later engine I'd like to connect up the oil pressure switch. How do I achieve this? The wiring from the switch is all there, I just need some advice on how to connect it all up to a little light on the dash. Cheers ...
January 28th, 2011, 7:15 pm
Post Re: Wiring in an oil pressure light
The oil pressure switch on the engine earths the circuit.
So you want to take a live from the ignition switch's "run" position, run it through the bulb, and off to the switch. That simple.
January 28th, 2011, 8:04 pm
