View unanswered posts | View active topics It is currently May 1st, 2026, 8:50 pm
Reply to topic  [ 57 posts ]  Go to page 1, 2, 3, 4, 5, 6  Next
 Engine,
Post Engine,
sorry abuot the blankish thread title but didnt really know what to right,
now ive got a dyane engine,
my plans are to see if it runs, (hence shopping list in flea market)
after seeing if the engine will run, (if it runs ok then great, if not, then oh well) my plan is to strip the engine down and learn what is what, and on re assemble put new pistons and barrels in etc
my reason for this post, is what else whould i be looking to do,
i read a minute ago about doing the valves while your there... tell me more sir's...
im after suggestions, not abuse, arguments, just advice and suggestions please :D
thank you :D
April 25th, 2011, 10:50 pm
Post Re: Engine,
Hi James,are you going to strip the engine down to the crank?Shame you could'nt hear it running before hand.
April 25th, 2011, 10:53 pm
Post Re: Engine,
dave,
going to try run it up first, see if it sounds ok, it has a squeeky valve, and turns over, so will mostly be running it up before hand, or trying......
i dont know how far to strip it down, im hoping for some pointers.... and after that, break out mr haynes manual and shut the door and get on with it!!!!!!!!!!
April 25th, 2011, 11:06 pm
Post Re: Engine,
If the crank is ok,(no knocking) then just fit new barrels and pistons,new oil pump,crank seals and strip heads.Lap the valves in, new valve stem seals etc. and that should sort it.Easy peasy :lol:
April 25th, 2011, 11:09 pm
Post Re: Engine,
hello haynes manual....
im hoping not to need advice on anything as im hoping to work it all out, / read haynes manual when im stuck,....
not promising though ;)
April 25th, 2011, 11:11 pm
Post Re: Engine,
Just take your time and you'll be fine.Read the mannual before you strip the engine.
April 25th, 2011, 11:13 pm
Post Re: Engine,
Why not just stuff it into your car one Friday evening and see if it makes noises?
April 25th, 2011, 11:25 pm
Post Re: Engine,
cos i use my car a hell of alot, and i dont want to worm my way into a position where im stuck without a car, realisticly i probably will do that anyway, but we will see...
i need to modify the air thingy for the dyane air box to go around the head lamp bar, will do a bit of diy with that i think...
i will read manual dont worry
April 25th, 2011, 11:31 pm
Post Re: Engine,
Or bolt some 2CV tinware onto the Dyane engine....
April 25th, 2011, 11:33 pm
Post Re: Engine,
i quite want the forced air intake for the carb, not sure why, but i feel like using the tin ware on there anyway...
April 25th, 2011, 11:37 pm
Users browsing this forum: Bing [Bot] and 95 guests
