View unanswered posts | View active topics It is currently April 29th, 2026, 3:14 pm
Reply to topic  [ 2 posts ]
 Gear lever bush
Post Gear lever bush
How to?
Seen and tried some options. None any good really.
I now cut, replace the bushes and weld it again. Heard of an englishman doing this without cutting.
Do you know the secret?
January 20th, 2011, 3:43 pm
Post Re: Gear lever bush
make a pattern of it / mould, heat it up, bend, remove, replace bushes, push back through, re bend to mould / pattern?
if life was only so simple
January 21st, 2011, 1:23 am
