Reply to topic  [ 6 posts ]
 Dull headlight
Post Dull headlight
For some reason one headlight is doing the being really dull thing, I've heard that it is usually an earthing problem? Does anyone have any ideas where I should start looking? I have taken the lens cap off and looked at the wiring but there is nothing obvious.
Thanks for any help.
Justin
Charlie is gone. Now 2CVless.
January 8th, 2011, 5:29 pm
Post Re: Dull headlight
Try giving the connectors under the head lamp bar a clean.
January 8th, 2011, 5:56 pm
also, check the connectors in the loom that goes down the side of the fan cowling, there was a dodgy earth connection there when mine did this.
January 8th, 2011, 7:37 pm
Also, check the bulb itself, I had this today and thought it was an earth problem, but it turned out the bulb itself had gone completely silver inside although both main and dipped filaments were still working and dimly visible through the 'chromed' bulb. Don't think I've seen one of those before, wierd.
January 8th, 2011, 9:00 pm
That tends to happen with rear-light bulbs, but I've not seen it on headlamp bulbs.
January 8th, 2011, 11:16 pm
thanks for advice all, it was a dicky bulb! Should have tried that first :)
January 10th, 2011, 8:42 pm
