View unanswered posts | View active topics It is currently April 29th, 2026, 11:24 am
 Engine Running like a sack of bolts
Post Engine Running like a sack of bolts
Hello
My engine is idleing like a sack if poo. When you idle, and Rev using gas pedal, there's a pause then take it off gas pedal and then it revs on it's own. I thought return spring but thats fine and dandy.
Any ideas?
Thanks
December 4th, 2010, 2:54 pm
Post Re: Engine Running like a sack of bolts
Its the batter.... no no
Maybe air? You were doing things with the fuel pipes? I have no idea though... just a thought.
December 4th, 2010, 3:03 pm
Basics first. Have you checked the throttle cable is nice and free, nothing in the way of the lever on the carb, like the wiring loom.
December 4th, 2010, 3:04 pm
It may be the mechanism on the carb that is a bit worn, so causing it to jam slightly.
December 4th, 2010, 3:35 pm
after f**king about in the snow did you check there is no moisture in the points box* or the lt lead to the points( from the coil)
then check that the springs and returns and cable are ok on the throttle side of things the linkages and extrematies of the engine will get a lot of condensation on them and it may be enough to cause it to stick, also if you like to spray everything with wd40 or the like it will have gone thick and sticky in the cold
moisture in the trottle cable and the cold will make it stick and be slow to respond
muff on and its all toasty and warm?
also you had the pump off any chance that water /snow could have got in while you were working?-hand over the carb trick
a clean engine never suffers in the cold, dirty ones hold the moisture which makes stuff stick and electricity leak- despite people thinking the waterproofing properties of oil are a good thing!
* remember Eurostar last year the snow blew about and got to places the larger water droplets didnt get, then when got into the warm tunnel it melted and played havoc with the 'lectrics
December 4th, 2010, 3:42 pm
There might be one or two around here remember that quite well...
December 4th, 2010, 5:00 pm
There was a lag in revving. Revved straight from carb still the same. After a good rev it seemsto be fine now. When I was driving I felt a bit of friction in the cable just now, then the pedal is as it should be. Think cable is catching or was. After a rev (wiggling the pedal, it was fine.) it was fine an hour go when I drove so I'll keep an eye out on it. It isn't seem eletricsl as it was firing on all cylinders so I will report back soon! It's done 50 miles since replacing pipe if not more a it's Ben faultless.
December 4th, 2010, 5:49 pm
Jameswallace wrote:
it's Ben faultless.
Him again? Is he on the forum?
December 4th, 2010, 8:17 pm
James,maybe the carb was just iced up?
December 4th, 2010, 10:18 pm
12 hours of my life and £120 I will never see again.
Jameswallace wrote:
it's Ben faultless.
Sounds like some trendy DJ type.
December 4th, 2010, 11:00 pm
Users browsing this forum: No registered users and 86 guests
