| Loud screachy Noise from Somewhere!! http://international2cvfriends.com/forum/viewtopic.php?f=7&t=2489 |
Page 1 of 3 |
| Author: | Matt_S [ November 30th, 2010, 3:47 pm ] |
| Post subject: | Loud screachy Noise from Somewhere!! |
Following the starting of the beast!!!.....once running it has a very loud screach (really ear piercing) coming from somewhere, gets louder when revving!! Clutch??? Release Bearing??? Or something??? Anybody got any ideas??? Looks like the engine is coming out again....D'oh!!!! |
| Author: | ginger bloke [ November 30th, 2010, 4:11 pm ] |
| Post subject: | Re: Loud screachy Noise from Somewhere!! |
alternator belt slipping, alternator bearing, metal cover over said belt catching on pulley. |
| Author: | Matt_S [ November 30th, 2010, 4:53 pm ] |
ginger bloke wrote: alternator belt slipping, alternator bearing, metal cover over said belt catching on pulley. Sorry its a no no and no.. There is No belt on at present and Sorry Forgot to say its.....A GS engined Beast |
| Author: | lpgo [ November 30th, 2010, 6:28 pm ] |
Quote: "There is No belt on at present and Sorry Forgot to say its.....A GS engined Beast |
| Author: | lpgo [ November 30th, 2010, 6:38 pm ] |
Could be the clutch fork; not sitting at the correct location. Clutch fork is hitting the clutch housing. Is your clutch cable on tension enough or is it loose could be your clutch cable too then (hitting the clutch housing) When your clutch cable is mounted correctly put down your clutch pedal and see if the sound then dissapears, then it will be your clutch bearing. Try to locate where the sound comes from front; back; left or right side from the engine it will help (us) |
| Author: | Matt_S [ November 30th, 2010, 8:52 pm ] |
lpgo wrote: Could be the clutch fork; not sitting at the correct location. Clutch fork is hitting the clutch housing. Is your clutch cable on tension enough or is it loose could be your clutch cable too then (hitting the clutch housing) When your clutch cable is mounted correctly put down your clutch pedal and see if the sound then dissapears, then it will be your clutch bearing. Try to locate where the sound comes from front; back; left or right side from the engine it will help (us) Hi Ipgo, No alternator belt at present as it doesn't want to fit on, I thought I ordered the right one but seems too small, but I have fitted 2 new cam belts and tensioners.. Also replaced the clutch all 3 pieces, so I was thinking it might have something to do with that, all seemed to go back on fine!! But looks like its going to be an engine out job!! Bugger!!!!!!!!!!! |
| Author: | toomany2cvs [ December 2nd, 2010, 1:00 am ] |
Matt da cote wrote: But looks like its going to be an engine out job!! Bugger!!!!!!!!!!! Where is the noise coming from? No point in pulling the engine if the noise is at the front. I'm quite liking lpgo's suggesting of cambelt rubbing on cowling. What torque did you do the front crank nut to? It's meant to be STUPID tight then peened, IIRC. If that works loose, then the cambelts can go for a wander in very short order, which is not something you really want to happen. |
| Author: | Matt_S [ December 2nd, 2010, 1:36 am ] |
toomany2cvs wrote: What torque did you do the front crank nut to? It's meant to be STUPID tight then peened, IIRC. If that works loose, then the cambelts can go for a wander in very short order, which is not something you really want to happen. By that you mean the gret big nut connected to the fan itself?? I'm sure i locked (well held tight the flywheel) and gave it a good tugging!!! The nut that is!! From what I can recall on Monday night, the noise seemed to be coming from the middle not the front!! I've had belts rub in the past but it never sounded like this....Really was ear piercing, almost had to cover ya ears it was that good!!! Probably should of try to get it running before I replaced everything, Cam belts, tensioners, plugs leads coil dizzy cap, complete clutch etc, might of had a better idea, by a matter of elimination!! Following Ipgo reply The clutch, plate or bearing, or something in there is probably the most likely, Could it be a knackered (but New) release bearing, but don't bearings make more of a rumble than a high pitch screach!!!??? No doubt we will get there in the end, just have to take it all apart Again... But thats the whole fun of owning one of these rare beasts I suppose..!! |
| Author: | Joolz [ December 2nd, 2010, 1:51 am ] |
Is the clutch cable fitted yet, if it is coming from the clutch then treading on the pedal should have some effect on the noise, not saying it will go away, but it would probably change some how. If the cable's not connected yet, it could be the bottom of the clutch fork rubbing on the flywheel. I had that happen before, although only turning the motor by hand, I went 'oh crap' for a minute before realising what it was. Check nothing's fallen between the crankcase and flywheel. |
| Author: | toomany2cvs [ December 2nd, 2010, 9:21 am ] |
Matt da cote wrote: From what I can recall on Monday night, the noise seemed to be coming from the middle not the front!! No doubt we will get there in the end, just have to take it all apart Again... Take the time to try to identify the source first. When you say "the middle", do you mean the centre of the crankcase? Or the clutch area (middle of the whole engine/box)? If it's the crankcase, then there's really only the crankshaft in there. It it is the crank, then I wouldn't even bother with diagnosis, just bin that engine and lob another in. |
| Page 1 of 3 | All times are UTC + 1 hour [ DST ] |
