View unanswered posts | View active topics It is currently May 1st, 2026, 4:10 pm
Reply to topic  [ 5 posts ]
 Idle mixture jet adjustment
Post Idle mixture jet adjustment
Im sure Ken wrote on here somewhere how to adjust the idle mixture but. I cant seem to find it now anyone know how to or where the how to bit about this is on here????
November 10th, 2010, 9:57 pm
Post Re: Idle mixture jet adjustment
goes something like this:-
start and warm up the engine
unscrew the offset slot idle(CO2) jet till you get a nice stable tick over
set the idle to 950rpm edit should be 850 with the knurled stop nut on the linkage.
then screw the offset screw in 1/2 a turn wait a bit do it again
keep going till the tickover begins to falter then screw it back out by 1/2 a turn
it helps to blip the throttle now and again during the screwing in stage
oh and it helps if the timing and tappets are spot on before you start
awaits confirmation and criticism ;)
November 10th, 2010, 10:31 pm
Cool I will give that a go thanks Sean.
November 10th, 2010, 10:53 pm
see also this
tho' there is an element of "groundhog day" and FWIW the "factory manual" instructs to pretty much do as above post, ajusting the engine speed with the appropriate butterfly stop screw etc
November 10th, 2010, 11:13 pm
[quote="Sean"]see also this
Blimey - I actually remembered that post - I've learnt alot in 18 months..... :lol:
now i just worry about body rot.... :(
November 11th, 2010, 12:38 pm
