| fuse related questions http://international2cvfriends.com/forum/viewtopic.php?f=7&t=2398 |
Page 1 of 1 |
| Author: | J-dub [ November 3rd, 2010, 7:10 pm ] |
| Post subject: | fuse related questions |
right, so im replacing the old fuse box with nice modern miniblade fuses, as i had a problem the other day, dodgy connection, and the wipers parked up and refused to work as ddi indicators, i also have tons of fuse holders and mini blad fuses, no citroen fuse box type ones though, now, assuming i have the fux box the right way up, could anyone tell me what each wire does? i plan on labelling it with the dymao thing so i know for future reference when a fuse blows! |
| Author: | J-dub [ November 3rd, 2010, 7:13 pm ] |
| Post subject: | Re: fuse related questions |
also if posisble what size they are?? i know i can work it out so dont worry if not but please say if you do |
| Author: | ken [ November 4th, 2010, 1:35 pm ] |
James, this any good? < http://www.flickr.com/photos/30132857@N06/4179544634/ > 10 amp fuses for everything except the circuit feeding the voltage regulator, wiper motor, etc. Re. that problem you've got with a headlamp bulb, sounds as though a filament is broken and making intermittent contact. Replacement is your best option... ken |
| Author: | J-dub [ November 4th, 2010, 1:52 pm ] |
Thanks ken, will do. Done fuse holders, will replace bulb |
| Author: | twofifty AZU [ November 4th, 2010, 1:56 pm ] |
Also check the resistance between the headlight bowl and the chassis. The path back to earth goes through a lot of joints on the factory setup. Quite often I add an earth wire into the factory headlight bar loom. I like the headlights as bright as possible. |
