rebel2cv
 Cracked primer
Right, yesterday I spent the day rubbing down my front wings, sorting out any stone chips and scratches, I then primed and gave it a coat of paint. Today I went out to finish the second wing but noticed that the wing I sprayed had not quite got the finish I wanted (it looks absolutely shocking!)  Everything was bone dry, I left the primer for a few hours before I painted, I'm guessing it's the primer as the paint hasn't peeled. Why has it done this??
| November 2nd, 2010, 2:30 pm |
rebel2cv
 Re: Cracked primer
Was it because I didn't laquer the paint?
| November 2nd, 2010, 2:32 pm |
J-dub
 Re: Cracked primer
if it where me, i would rub it done with some 600 wet and dry, working up to 1200, get it flat and go from there!!
ps i need to speak to my gf to see if shes got the request or whatever it is
| November 2nd, 2010, 3:30 pm |
Devils Advocate
 Re: Cracked primer
Hi Rebel. Looks as tho' there's some paint-incompatibility going on there. Since it's the primer coat that's 'moved' - shrinking when the top coat was applied - my suspicions are that the primer was not compatible with whatever was underneath it (you're going to tell me now it was put on to bare metal and shoot me down in flames, aren't you...  ) What type of primer and top coat was used? And what was the primer applied to?
| November 2nd, 2010, 4:26 pm |
Old-Nail
 Re: Cracked primer
I'd go with that. It looks like incompatibility, did you check what type of paint was on there originally? It's possible that you have used lacquer paint over an enamel based primer to get those results.
Putting on too thick a layer of topcoat can also get you those wrinkles. Several thin coats with adequate drying time in between is the way to go. Unfortunately the only fix for what you have there is to take it all off again.
| November 2nd, 2010, 5:32 pm |
lpgo
 Re: Cracked primer
another possebility is that the paint reacts to the primer, so the primer is allright, the paint is allright but the combination of the 2 together goes wrong,
I take all products from 1 supplier so everything matches.
p.s. when the primer was wrong to the underground you would have this reaction before the painting...........
(I'm not an (paint) expert so everything I write (here) is at your own risk)........
| November 2nd, 2010, 6:27 pm |
lpgo
 Re: Cracked primer
what a pitty? yesterday I looked at your pics and I was jealous at your result!!
| November 2nd, 2010, 6:32 pm |
rebel2cv
 Re: Cracked primer
I was proud till this morning lol it wasn't quite bare metal all what was in there was well sanded and rough, can't wait to start over  lol trouble is it's the same paint and primer I used for the rear arch and didn't have a problem, I'll rub the other wing down to metal and try that
| November 2nd, 2010, 6:59 pm |
Will2cv
 Re: Cracked primer
I've had similar when the primer was laid down too thickly so could well be that, in the absence of any other reaction with the topcoat etc. A rub down and try again seems the best option.
1979 2cv6 (Evie) 1983 Beachcomber (Mavis) 1974 AZU250 Belgian PO (The van) 1991 AXGT Mk1 2008 C5 2.0 HDi VTR+
| November 2nd, 2010, 7:09 pm |
rebel2cv
 Re: Cracked primer
  New wheel colour worked though
| November 2nd, 2010, 7:14 pm |
