View unanswered posts | View active topics It is currently April 30th, 2026, 4:29 am
Reply to topic  [ 7 posts ]
 OIl feed to valve gear
Post OIl feed to valve gear
Does the oil feed to the rockers only reach one valve? I can find only one hole-under the valve spring retainer on the inlet valve. Is there another hole that supplies the exhaust side?
Reason for this question- There does not appear to be adequate oil reaching the rockers one one cylinder.
November 1st, 2010, 10:05 pm
Post Re: OIl feed to valve gear
socarco,
the oil feed pipes deliver oil into galleries around the exhaust valve guides, which helps keep the exhaust valves cool.
Have a good look at the outside of the cylinder heads, where there's an M7 threaded hole to which a banjo bolt connects the oil feed pipes.
I've never yet found an engine on which oil couldn't pass through the feed pipes, or onwards through those tapped drillings into the rocker covers... :?
November 1st, 2010, 10:29 pm
so how do you work out there isnt enough oil
is the valve chest dry or something?
November 1st, 2010, 10:43 pm
Yup! after a few minutes test run there is no oil visible on rockers.
November 1st, 2010, 11:12 pm
socarco,
have you tried spinning the engine over with the plugs out and the rocker covers removed?
As soon as there's _any_ oil pressure in the system, oil should be observed to be leaking from under the exhaust valve springs.
November 2nd, 2010, 12:03 am
any muck is likley to stick in the drillings of the bajo bolts
if it were mine id take the bolts out and have a good poke about with a bit of mig wire
sean
ah and check that the pipe has not been bent and flattened as the bolts were tightened up and also make sure the pipes have not been dammaged by being knocked.
November 2nd, 2010, 9:12 am
ive got new flexi stainless pipes to go one, look the treat they came with this anti sieze paste, i can only assume that it goes on the threads of the banjo bolts?
November 2nd, 2010, 11:04 am
Users browsing this forum: No registered users and 75 guests
