Page 1 of 1
[ 5 posts ] |
J-dub
 fuse related questions
right, so im replacing the old fuse box with nice modern miniblade fuses, as i had a problem the other day, dodgy connection, and the wipers parked up and refused to work as ddi indicators, i also have tons of fuse holders and mini blad fuses, no citroen fuse box type ones though,
now, assuming i have the fux box the right way up, could anyone tell me what each wire does? i plan on labelling it with the dymao thing so i know for future reference when a fuse blows!
| November 3rd, 2010, 7:10 pm |
J-dub
 Re: fuse related questions
also if posisble what size they are?? i know i can work it out so dont worry if not but please say if you do
| November 3rd, 2010, 7:13 pm |
James, this any good? < http://www.flickr.com/photos/30132857@N06/4179544634/ > 10 amp fuses for everything except the circuit feeding the voltage regulator, wiper motor, etc. Re. that problem you've got with a headlamp bulb, sounds as though a filament is broken and making intermittent contact. Replacement is your best option... ken
| November 4th, 2010, 1:35 pm |
J-dub
Thanks ken, will do. Done fuse holders, will replace bulb
| November 4th, 2010, 1:52 pm |
twofifty AZU
Also check the resistance between the headlight bowl and the chassis. The path back to earth goes through a lot of joints on the factory setup. Quite often I add an earth wire into the factory headlight bar loom. I like the headlights as bright as possible.
| November 4th, 2010, 1:56 pm |
Page 1 of 1
[ 5 posts ] |
Users browsing this forum: No registered users and 52 guests |
