View unanswered posts | View active topics It is currently May 1st, 2026, 12:10 pm
Reply to topic  [ 6 posts ]
 AMI 6 window rubber
Post AMI 6 window rubber
Hi folks. Was wondering if there is s(l)ide window rubber for an AMI 6 available somewhere?! Reproduction or something?
Vennlig hilsen, Eirik
And a Heinemann Z412 -80
October 26th, 2010, 12:28 am
Post Re: AMI 6 window rubber
Try this mob
http://www.woolies-trim.co.uk/c-310-double-track.aspx
October 26th, 2010, 9:57 am
The Dutch "amivereniging" got them too but I don't now prices.
http://www.amivereniging.nl/
October 26th, 2010, 12:18 pm
Hi there
I replaced mine using the 22mm channel in this link, it works well - doesn't slide about or lift / bend when opening the windows
but do note that i had to drill holes / slots through the rubber to meet up with the drain slots in the door top - fairly easy, craft knife and very sharp drill bit.
depending on what rivets you use - you may find that standard rivets (to hold the internal chrome strip on) tend to squash the channel in a few places, but not so much to stop the glass sliding past.
however, I believe John Sobey may have used an alternative to this - possibly from an English classic stockist? you would have to ask.....also heard that some Landrover channel can do the job....
That's everything I learnt when I did mine....
door tops are so vunerable on these Amis!!!!
good luck
Will
October 26th, 2010, 4:26 pm
Thanks a lot guys.
By the way, discussed in some other thread, about using a rear door from a sedan on a Break. Just replaced my left rear door on my break with the spare-door from a sedan. Fitted like a glove. Had to dismount the window-frames of course, as they are not the same. (This is only possible on AMI 6's before October(I think) 1968, who has the bolted on aluminum window frames)
October 26th, 2010, 7:20 pm
EirikJ wrote:
Thanks a lot guys.
thanks Eirik - interesting, I will try mine again....
October 27th, 2010, 2:49 pm
