Reply to topic  [ 9 posts ]
 Lou noise at flat out
Post Lou noise at flat out
Wierd noise when i floor it, sounds like theres no exhaust, but there is, only whenyou floor it.
The engine was low on oil so i hadto drive 1 mile with just below bottim nark and get oil, i hadto buy total quartz 15w40 performance. Or nothing else!
Any ideas?
Just sounda like no exhaust!
October 18th, 2010, 11:33 am
Post Re: Lou noise at flat out
My uncle said he hear me pull up outside his place and sounded like no exhaust. Going to inspect later. Cross box is old rest is new so thats my start point
October 18th, 2010, 12:54 pm
Check that your air-filter cover is screwed on properly.
October 18th, 2010, 1:04 pm
I had checked that thi morning. May not of done it propelrly. Will check later
October 18th, 2010, 1:09 pm
Check over all of the exhaust joints - if you cup your hand around the joint, you'll feel a blow.
It's well worth having a good look all over, too, first thing on a cold morning, since you might well see any exhaust gases.
A trick I've used in the past is to dribble a little engine oil down the carb throat with the engine running. Again, it makes the exhaust very visible, so you'll see if the gases are escaping. It takes a little while to work fully, because the oil tends to sit in the inlet manifold for a bit. We did that to Jono's car at the French Nat'l this year - nothing visible at first, but we found and sorted the blow fairly quickly. Then, later, when they went into town... Smokescreen!
October 18th, 2010, 1:25 pm
if you had a backfire at some point in the latest round of calamity then check the heater tubes/balance pipe that run from the exhaust manifold stub to the carb
also the cross box , spigots swan neck etc
October 18th, 2010, 6:09 pm
If it;s just when you're flat out, then in my experience you're air filter is popping up. I've seen cars with threaded rod through the entire assembly to keep it down.
October 18th, 2010, 9:47 pm
It's worth looking at the swan neck, too. Ellie's car had a pinhole in the swan neck, where the clamp had chafed through. Quiet, until you hit the second choke.
October 18th, 2010, 9:52 pm
Once again the forum members arerigjt, air filter, combination of it falling of top of carb and me forgettingto screw the samn thing back on. Woops. Ive had issue with it falling of the carb before and thought id sorted it
thankd boys :)
October 18th, 2010, 10:31 pm
