Reply to topic  [ 5 posts ]
 Carburetor gasket
Post Carburetor gasket
The gasket between the 2 halves of the Carburetor fits under the float swivel bar as shown in the picture.
The is obviously a way of getting this bar off to replace the gasket.
Anyone know how it comes apart?
October 14th, 2010, 10:50 pm
Post Re: Carburetor gasket
is there not a pin that you push out? or is it spring loaded on?
October 14th, 2010, 10:53 pm
Norman,
you need a small drift ( read as drill bit or nail) to tap that bar out.
Btw, you shouldn't have been able to remove the float with the bar still in place, so best to close up those 'fingers' which form the support for the float assembly before refitting it...
October 15th, 2010, 12:48 am
Thanks Ken that seemed to be the only way but i didnt want to use too much force and crack the casting.
yes I did push on one of the lugs to get the floats off. :oops:
October 15th, 2010, 11:09 am
Dont loose the pin!
October 15th, 2010, 11:22 am
