 Heavy Duty Battery?
Post Heavy Duty Battery?
Is it ok to put a heavy duty battery on the 2cv?
Charlie is gone. Now 2CVless.
October 6th, 2010, 9:41 am
Post Re: Heavy Duty Battery?
'Officially' - I don't know. ;)
There are perhaps many reasons why standard rated equipment should be used or is recommended. Unofficially, or should I say in reality, I have used a HD battery for the last four or five years with no ill effect to any other components.
October 6th, 2010, 12:33 pm
Yes. They are all 12V. All that differs is the amount of electrickery they can store - its capacity. And the greater the capacity, the more useful it should be.
A battery's capacity is usually in the form of Ah (ampere hours) which is the number of amps it can deliver for one hour. Eg: an 80 Ah battery should be able to deliver 80 amps for one hour before going 'flat' (keeping terms technical here...). The same battery could instead supply 40 amps for 2 hours, or one amp for 80 hours.
A 'heavy-duty' battery will essentially have a greater Ah capacity than a 'standard' one, tho' there'll probably not be a huge difference. This should make it capable of giving a longer - and probably more powerful - cranking time. Or, you should be able to keep your lights on - or radio playing - for longer with the engine off.
I can't see any problems with a higher capacity battery. I guess, in theory, a very high capacity battery which is allowed to become discharged might place a large strain on the feeble alternator in a 2CV once it's fired up, but I doubt that would happen unless you stuck a couple of truck batteries under your bonnet...
When it comes to replacing a battery, I usually plum for a higher capacity one than the original of its type - ie: the same physical size and terminal type as the original. It shouldn't be 'needed', but it's always nice to have that little bit more power when it's called for.
Justin - do you know what the respective capacities of the two batteries are?
October 6th, 2010, 12:35 pm
I've just bought one of these:
520 CCA
52Ah
I *think* it's one of the more powerful batteries availiable in 063 flavour.
October 6th, 2010, 12:43 pm
That's a battery-for-life Neil. :P
October 6th, 2010, 12:46 pm
at £65, it better be! :lol:
October 6th, 2010, 12:48 pm
Wonderful! Thanks. HD batt it is then. Thanks all!
October 6th, 2010, 1:20 pm
Its a battery for as long as the guarantee lasts, after that its all bonus.
October 6th, 2010, 5:39 pm
Varta guarantee their batteries for longer than Citroen did their 2cv's. :lol:
October 6th, 2010, 6:30 pm
Why am I not surprised by that?
:lol:
October 6th, 2010, 6:33 pm
