Reply to topic  [ 38 posts ]  Go to page 1, 2, 3, 4  Next
 How much tie rod thread should be left in the end shackle?
Post How much tie rod thread should be left in the end shackle?
I want to lower the front of mine a bit further and wondered how much tie rod needs to remain in the end loop, i think I'd heard 1.5cm?
Weird thing is, at the back I only have 11mm of thread visible and at the front there's 110mm visable, yet still the rear wing hangs between the middle and top of the hubcap - i'd like the rear wing at the top of the hub cap.
Shall I just screw it all the way in at the back?
September 27th, 2010, 1:44 pm
Post Re: How much tie rod thread should be left in the end shackl
When you screw the tie rod 1 cm in or out, the car will raise or lower 4 cm.
The 1,5 cm could be right.
September 27th, 2010, 2:58 pm
Thats really useful, cheers Tom :)
September 27th, 2010, 3:32 pm
I'm sure Uncle Ken mentioned at least 10mm to me once.
September 27th, 2010, 4:32 pm
In the hex shaped shackles there's only 15mm of tapped length in the end anyway.
September 27th, 2010, 6:45 pm
remember the central cans should be floating and the cans set with a certain ammount of free play as well as the can supports being set up properly
you can wind up one end and it moves the other
however only 10mm left on the tie rod suggests somethings not right as all mine are nearer 40mm thread left front and back
sean
September 27th, 2010, 7:12 pm
Just to clarify this - I think Sam means "how much thread should be wound into the shackle as a MINIMUM to be safe?"
For instance, you wouldn't only wind it in a couple of turns so it just bites, would you :o
September 28th, 2010, 2:35 pm
Clean out the tie rod end eye to see how much thread there is. That should indicate your minimum.
September 28th, 2010, 2:48 pm
This is what I meant :) Thank you Bertie! As a minimum I'm taking 15mm.
September 28th, 2010, 4:44 pm
if you had problems, you could always get those longer tie rod ends sam?
September 28th, 2010, 6:14 pm
