View unanswered posts | View active topics It is currently June 19th, 2026, 10:13 pm
Reply to topic  [ 57 posts ]  Go to page 1, 2, 3, 4, 5, 6  Next
 Single point injection
Post Single point injection
Does anyone know if there is a single point injection kit for the 2cv? Rather than the megasquirt option. How much can you dump from the engine by doing it? ie carb etc.
Thanks.
Charlie is gone. Now 2CVless.
September 14th, 2010, 7:12 pm
Post Re: Single point injection
I'm no mechanic by any stretch of the imagination, but I doubt single point injection would improve on a tried and tested design, stick with what you've got. :)
September 14th, 2010, 7:24 pm
you could put a webber carb on but say good bye to your mpg and hello to your gpm.
September 14th, 2010, 7:29 pm
I seem to recall that 123Ignition were developing an SPI kit, although I can't think of any off the shelf kits on the market at the moment.
What are you hoping to achieve by fitting it? More power, more mpg, more reliability?
September 14th, 2010, 7:37 pm
Better mpg I suppose, and not needing to replace a very very worn carb.
I was going to go for the reconditioned carb and 123 electronic ignition, but if injection was available I would have thought about it.
September 14th, 2010, 7:51 pm
the prior would be the most cost effective, and easiest to fix if it went wrong. i would think anyway.
September 14th, 2010, 7:57 pm
If you're serious you could have a chat with Geoff...
http://www.northallerton-engineering-se ... edshop.htm
http://www.2cv-speed-shop.co.uk/modifying.htm
September 14th, 2010, 8:28 pm
Yes its possible, but starting to be a custom job really. Perhaps I will get the carb sorted and the 123 put in and wait for sometime in the future for an off the shelf injection kit when someone decides to make one.
September 14th, 2010, 10:41 pm
ok
September 14th, 2010, 10:43 pm
Correct. They named it 123/carb (what's in a name). Can't find anything about it anymore. Looks like they stopped this project, although they had one mounted on a enginge:
On their site I also can't find anything about it...
September 14th, 2010, 10:53 pm
Users browsing this forum: No registered users and 201 guests
