Page 1 of 1
[ 1 post ] |
Matt_S
Joined: July 28th, 2010, 11:50 pm Posts: 590 Location: Northumberland
 What these Wires for??
First pic ok last pic should be easier for some of you (spanners??) Any ideas 3rd wire should be the alternator is there another one that should go there too??
And the 1st and 2nd wires??
Oil pressure switch and coil??
The other pics are a bit difficult as always when you see pictures rather than the in the flesh version.. 2 that are on the seat...One comes from the ignition goes through a 10amp fuse To the white ended bit on the seat..The other runs through the bulk head and to the 2 pin socket in the other picture and the other wire from the 2 pin goes to an earth on the voltage regulator!!
The other 2 which includes a picture of my rubber gloved hand...One is scotched straight from the fuse boxes thats the longer curled up one The other yellow wire comes out of the loom where it goes behind the dashboard
Any help or ideas on any would be helpful??
Cheers Matt
Dyane 12 1976 (ish)
| September 11th, 2010, 10:47 pm |
Page 1 of 1
[ 1 post ] |
Users browsing this forum: No registered users and 79 guests |
