View unanswered posts | View active topics It is currently May 1st, 2026, 11:35 am
Reply to topic  [ 32 posts ]  Go to page 1, 2, 3, 4  Next
 175 tyres on Gs Alloys will They fit?
Post 175 tyres on Gs Alloys will They fit?
Seen a couple of bargain tyres, but they are 175 R15, they should fit ok on a Gs alloy shouldn't they??
But will they fit inside the back arch of a Dyane without any mods??
If anyone can shed some light as Don't want to get them to find they don't fit!!
Dyane 12 1976 (ish)
September 2nd, 2010, 11:40 pm
Post Re: 175 tyres on Gs Alloys will They fit?
They definately won't fit on the back of your Dyane!
In fact, I'd be inclined to swap the rear arms on it for standard 2CV/Dyane rear arms as 145x15s would rub ever so slightly on the inner arches when she was laden and as GSA rims have a different offset too................. :ugeek:
September 3rd, 2010, 7:40 am
Cheers Jon
The wheel base is slightly wider on a Ami chassis then is it...
Might see if I can extend the rears wings out a few inches...
Think it would look quite good a bit fat at the back!!
Dyane 12 1976 (ish)
September 3rd, 2010, 8:50 am
No, the rear track is slightly narrower meaning they rub on the inner arches.
Coupled to the fact that the GSA rims have a different offset meaning they're even more likely to rub on the inner arches etc.
September 3rd, 2010, 9:04 am
Matt da cote wrote:
Cheers Jon
You mean narrower
September 3rd, 2010, 11:18 am
I think the wheel base is very similar if not the same as a 2cv, but the rear track is narrower on an ami.
September 3rd, 2010, 5:49 pm
Correct
September 3rd, 2010, 5:54 pm
Regarding tyres, I'm not sold on the idea of massive 175/80/15 tyres on a road car. Maybe back in the day that was the only way to get wider tyres, but if you want wider try smart car tyres. That's what I have and they are pretty good. 165/50/15 or 155/60/15 are what I've got. I think.
September 3rd, 2010, 6:00 pm
The more rubber gripping the road the more strain on drive shaft, wheel bearing et al. So unless everything else is uprated don't go too wide.
September 3rd, 2010, 6:04 pm
That what I'm after a stabdard smart runs 145's on the front and 175's on the back...I've got hold of a couple of smart 145's for the front just looking for the ones for the back...found a couple of new 175's for £50 only reason really I was looking...
Could spacers work??
Dyane 12 1976 (ish)
September 3rd, 2010, 10:17 pm
Users browsing this forum: No registered users and 114 guests
