Reply to topic  [ 5 posts ]
 indicator stalk and wiring
Post indicator stalk and wiring
Hi,
Two questions tonight which I could probably answer if I hadn't loaned my 2cv to a friend:
- what holds the indicator switch to the steering column?
- anyone happen to know the colour codes for the wiring loom connections between rear wiring and the loom itself in the engine bay (on the bulkhead)? I couldn't find any useful colours in the haynes - this is for my 1975 car, in case it makes a difference.
Thanks! Ben
August 26th, 2010, 9:01 pm
Post Re: indicator stalk and wiring
oops, cancel the second question. It's in the 2cvgb handbook, and a very useful fellow's photostream on flickr (thanks Ken, that's twice your photostream has come in useful in 24 hrs!)
August 26th, 2010, 9:07 pm
It sits on a bit of steel bracket that slides up inside the switch near to the steering column end - the bracket is held on to the column via the lighting switch assembly....
August 26th, 2010, 9:48 pm
Ah - that confirms my thoughts then - I've lost another bit! Thanks very much
August 26th, 2010, 9:57 pm
it tends to slide of at the worst times too!!
August 27th, 2010, 9:34 am
