View unanswered posts | View active topics It is currently June 28th, 2025, 1:50 pm
Reply to topic  [ 7 posts ]
 help! fairly urgent!
Post help! fairly urgent!
well, while bridging my dim dip, someone distracted me, and i bridged instead of one to 5 i think 1 to the other one by mistake without realising, i then turned my headlights on and smoke poored out the switch, and then i realised that the brown wire (either one or 5 i believe) is completly melted down the loom!
what is the brown wire?
and i have a spare loom, do i patch this loom up, the wire is completly melted and gone, it is the only one that has done so, i took the switch apart to see if any damage there, but there is no brown wire to there either,
is there anyone near ish me to come help me sort this out as i need to get this fixed asap! im pretty sure that ive shorted it out, well obviously i have!
and if can patch it shall i nick a bit out of the loom and how do i patch it
help!!!!!!!
August 23rd, 2010, 4:06 pm
Post Re: help! fairly urgent!
also, whilst taking head light switch apart, it all fell apart, how does it go back together! didnt see how it came apart as it all sort of sprung out!
August 23rd, 2010, 4:09 pm
I've got a spare headlight switch. Any use to you?
August 23rd, 2010, 4:12 pm
the headlight switch is fine ( i think!)
just not sure what this brown wire is and what i need to do!
August 23rd, 2010, 4:14 pm
also, is there any other thing that will be burnt out or i should look out for>
August 23rd, 2010, 4:17 pm
You going to the InterNational this weekend? Its pretty near you and ther'll be loads of people that can help you out
August 23rd, 2010, 4:24 pm
semi sorted
the brown wire is an earth, and i obviously hooked it up to a live by mistake...
woops
if i disable dim dip it makes it redundant anyway so all is not lost!
it melted another wire, well pretty much, but lukily that is also an earth, and where it goes up, it is earthed futher up with a load of wires so defeates the object of that part of the loom, so its not the end of the world lukily, but i am going to buy a new loom, or see if the one i got is good enough, so to put it back to originality!!
August 23rd, 2010, 5:33 pm
