Reply to topic  [ 5 posts ]
 wiring question
Post wiring question
im going to wire in a 12v ciagarete adapter thingy (to charge my phone and ipod in the car) and was after some suggestions as to where to creep a wire through the bulkhead to obtain a 12v source,
ive just wired in a new cd player, as i got a better one out my sisters car when she wrote it of last week!! and looking at the wire its not going to be thick enough to power both charger and cd player without over loading the wire..
as its the original wire for the original radio
i saw that i could creep it through via the hole for the speedo cable, but just want to know if theres any better places or bad implications of putting it through the speedo cable...
is there a way i can wire it into the fuse box to avoid having to buy a inline fuse and to make it tider, i have a spare look so could nick bits of if i really had to to get it into fuse box...
hope that makes sense
August 21st, 2010, 8:31 pm
Post Re: wiring question
You should always try to send wire through existing holes preferably those that already have a rubber grommet to protect the wire. It should always be fused before it passes through the bulk head either from the correct side of the fuse box or with an in line fuse.
August 21st, 2010, 11:57 pm
yer, i dont want to drill a hole, i was thinking maybe the headlamp bar adjuster, as i dont ever adjust them!
is the speedo cable one alrite? and i was going to fuse it either way!
August 22nd, 2010, 12:14 am
Its as good as any as there is usually a good rubber sleeve in there.
August 22nd, 2010, 12:21 am
ill go for speedo cable then
August 22nd, 2010, 12:32 am
