View unanswered posts | View active topics It is currently May 1st, 2026, 12:12 pm
Reply to topic  [ 2 posts ]
 Car Body Sealer
Post Car Body Sealer
Just invested in a tube of Indasa Car Body Sealer
so that I can seal the deep seam above where the bonnet hinge meets the body, just under the cabin air vent.
What I want to know is: will the sealant go hard in the tube if I don't use it all in one go? I only need to use about 1/10th of the tube's contents for this job. The contents are highly flammable, so I'm guessing it won't keep if the seal is broken, but I'd appreciate anyone's advice and experience with this type of product.
August 15th, 2010, 8:48 pm
Post Re: Car Body Sealer
It's probably polyurethane. It reacts with moisture in the air so it'll go off quite quickly once the seal is broken.
August 15th, 2010, 8:55 pm
Users browsing this forum: No registered users and 105 guests
