Russell
 Unwinding a gearbox.
Anybody fancy putting up a set of clear and detailed instructions on how to re-wind a gearbox? very soon?
If not, expect an idiots guide, coming soon.
| March 14th, 2009, 12:03 pm |
toomany2cvs
 Re: Unwinding a gearbox.
Russell wrote: Anybody fancy putting up a set of clear and detailed instructions on how to re-wind a gearbox? very soon?
If not, expect an idiots guide, coming soon. Step 1. Make sure the fire in the wiring loom has been extinguished. He's a national treasure is our Russ.
| March 14th, 2009, 12:36 pm |
Luke
erm... there was an article in the mag within the last few months, if you can find one of them. Think i've got one on the computer somewhere....
| March 14th, 2009, 12:43 pm |
Russell
I've found some instructions which I've printed out, I can't say I understand them, but I'll have a go, and rtake some pictures, and if all goes well, write it up here.
| March 14th, 2009, 12:44 pm |
Russell
Right, despite what seemed like clear instructions, I've hashed this up.
opened box, located the collar that was flapping about like a prick in a bucket, 'ideal', thinks me, 'that looks easy'. Well it was and it wasn't, Ive screwed the collar back on, and peened it over. Put it back together, went to try it and despite the gearlever being where it was before in neutral, it seems something's moved and the car was actually in a gear, and jumped forwards. The gear lever now sits in what appears to be neutral about 2" further back than before. When I lift the clutch up, even in neutral it's making a horrific grinding noise like somethings isn't engages properly, or is trying to engage when it shouldnt. I've opened the box up again hoping to see an obvious fault, which I cant. What have I done wrong? despite the collar being screwed back on and peened (it hasnt moved since) the car still makles the noise it did before, and now the gearstick's in a different place.
| March 14th, 2009, 2:53 pm |
Russell
 Took it to bits...   Screwed this collar back on... Didn't drop this inside...  so where did i make a mash of it then?
| March 14th, 2009, 3:04 pm |
toomany2cvs
Russell wrote: The gear lever now sits in what appears to be neutral about 2" further back than before. Assuming you didn't slacken the pinch bolt where the gear lever fits to the selector coming through the lid of the 'box, I think you've managed to rotate that selector. It's on a ball to allow fore-aft and side-side movement, but IIRC it's keyed to prevent it rotating - if it is, then it might be that one or more of the selector slides are out of line. I think you're going to need to figure that out, and to make sure all the selector forks are in neutral before you put the lid back on. The second one of those pics shows the middle selector - 2nd/3rd - slid forwards, so in 3rd. The bottom selector - 4th - is in neutral, the top - 1st/reverse - is in neutral.
| March 14th, 2009, 3:08 pm |
Tim2cv
gym bunny
Joined: December 8th, 2008, 4:08 pm Posts: 806 Location: Burton-upon-Trent
your one of a kind Russ!!! http://www.2cvstuff.com/2CV_yourstuff_index.htmlPDFs might be of some help on there
 1299cc FTW
| March 14th, 2009, 4:43 pm |
Russell
Well, bizzarely, it works now. Rick, the gearbox guru called me (thanks Ade) and talked me through what was likely to be wrong, although most of the conversation involved me looking at a gearbox blankly while Rick described components I've never heard of or seen before. Everything he said was already as it should be, so I put the top back on, and it works. I've yet to go and take it up the road (because I'm too much of a pussy, and it'll probably break) but a little bit of trying it5 up the drive and it seems to be ok. I still have no idea what I did wrong, or to be honest, whether I've fixed it properly, but there you go...
| March 14th, 2009, 5:18 pm |
toomany2cvs
Russell wrote: Rick, the gearbox guru called me (thanks Ade) Since you were sulking and whimpering that you wouldn't call him and didn't want to touch it any further, it seemed texting him and asking him to give you a call was the easiest solution...
| March 14th, 2009, 5:20 pm |
Users browsing this forum: No registered users and 201 guests |
