Page 1 of 1
[ 5 posts ] |
indicator stalk and wiring
meshking
Hi,
Two questions tonight which I could probably answer if I hadn't loaned my 2cv to a friend:
- what holds the indicator switch to the steering column?
- anyone happen to know the colour codes for the wiring loom connections between rear wiring and the loom itself in the engine bay (on the bulkhead)? I couldn't find any useful colours in the haynes - this is for my 1975 car, in case it makes a difference.
Thanks! Ben
| August 26th, 2010, 9:01 pm |
meshking
 Re: indicator stalk and wiring
oops, cancel the second question. It's in the 2cvgb handbook, and a very useful fellow's photostream on flickr (thanks Ken, that's twice your photostream has come in useful in 24 hrs!)
| August 26th, 2010, 9:07 pm |
Nelsthebass
It sits on a bit of steel bracket that slides up inside the switch near to the steering column end - the bracket is held on to the column via the lighting switch assembly....
| August 26th, 2010, 9:48 pm |
meshking
Ah - that confirms my thoughts then - I've lost another bit! Thanks very much
| August 26th, 2010, 9:57 pm |
J-dub
Nelsthebass wrote: It sits on a bit of steel bracket that slides up inside the switch near to the steering column end - the bracket is held on to the column via the lighting switch assembly.... it tends to slide of at the worst times too!!
| August 27th, 2010, 9:34 am |
Page 1 of 1
[ 5 posts ] |
Users browsing this forum: No registered users and 31 guests |
