View unanswered posts | View active topics It is currently June 19th, 2026, 2:03 am
 Shock absorber fitting instruction
Post Shock absorber fitting instruction
Monroe
Lip
Record
July 7th, 2010, 10:07 pm
Post Re: Shock absorber fitting instruction
Dampers aren't exactly a specialist job though! You* don't even need to jack the bastard up!!
*I do though. I can't get my hands under the car otherwise.
July 7th, 2010, 11:24 pm
Just to be clear... LIPs should be fitted with the 'fatter' end toward the spring can as per ecas instructions yes?
July 8th, 2010, 9:36 am
sam,
Lipmesa/Allinquant type should always have the sleeve end towards the chassis.
In addition, the fitting mark on the body of the damper must face upwards.
That fitting mark used to be an indent on the body, but more recently, it's been just a yellow paint mark... ;)
July 9th, 2010, 1:02 am
Front page updated with Record.
Talking about Record for Acadiane rear. Any alternative product around. Found the inside bushes too skinny collapsing when nuts are fasten too hard. Some customers are not able to remove the shockies due to this happening?
September 3rd, 2010, 2:49 pm
looks like the inner spacer/washers have been fitted the wrong way round
or is it a case of "well they fit so we will punt them off to un suspecting 2cv owners( well they are all lentil munching hippies after all)"
Had an alloy bodied Avo shock break this year and the metal is scarily thin at a critical point, definatley not designed for peak load to be in tension.
September 3rd, 2010, 3:32 pm
Also check this
viewtopic.php?f=7&t=2025
September 3rd, 2010, 4:25 pm
2CViking wrote:
602 wrote:
Oh yes please, can I order from you or the UK.
Thanks heaps.
I ordered direct from their web site and they delivered to France. Nice people too.
September 3rd, 2010, 5:32 pm
602 wrote:
2CViking wrote:
Thanks heaps.
It was a good try but no good for Acadiane.
The dimensions are 27 mm wide OK for 2cv but ACA is 38.50 mm
Thanks anyway
September 3rd, 2010, 5:58 pm
Thanks anyway
Have fitted them on the rears of aks400's, because they are in two parts and you retain the sleeve they squeeze together very nicely.
September 3rd, 2010, 6:02 pm
Users browsing this forum: No registered users and 223 guests
