Page 1 of 1
[ 7 posts ] |
Rhythm Thief
 Headlamps flickering
My electrics appear to be beginning to play up. The headlamps and dashboard lights are flickering quite badly every so often and the charge meter on the dash is occasionally dipping down towards the red. My voltage regulator is reasonably new and all my electrical connections appear tight. I've cleaned the earth on the bulkhead. My alternator brushes are a bit worn but don't look to be too bad. What else can I check? Electrics are not, shall we say, my strong point.
| July 1st, 2010, 11:08 pm |
J-dub
 Re: Headlamps flickering
a muppets opinion (mine) could be one of the wires has bad wire inside, or bad wire as in all choroded etc or could be a loose connections (Even though you said there all tight you never know) have you checked battery voltage? sorry if ive said what youve probably done
| July 1st, 2010, 11:14 pm |
Joe
have you checked the earth connections at the headlamp bar? thats where i had a bad/no connection when my lights started playing up
| July 1st, 2010, 11:15 pm |
Tom Duckpower
Joined: August 18th, 2009, 10:31 pm Posts: 1244 Location: Berkel-Enschot, Netherlands
On stationairy or on revs? When stationairy, that's normal since the alternator hasn't got much power @ low revs. Thing you can do about this, is place a relay between the wire from the contactor to the voltage regulator.
 1986 Citroen 2CV6 Special Pick-Up 1964 Solex Oto Van der Heem
| July 1st, 2010, 11:18 pm |
Nelsthebass
Sounds like a knackered voltage regulator to me - if its a electro mechanical one, ditch it for an electronic one.
| July 2nd, 2010, 7:13 pm |
Rhythm Thief
Nelsthebass wrote: Sounds like a knackered voltage regulator to me - if its a electro mechanical one, ditch it for an electronic one. it's got a solid state one on it already, and it's pretty new. My money is on a dodgy connection to the regulator, everything else looks ok.
| July 4th, 2010, 2:54 pm |
Nelsthebass
Ah right - I was just thinking that the replacement may have been the old style - I would get out the emery paper and clean all the contacts especially the earth....
| July 4th, 2010, 4:39 pm |
Page 1 of 1
[ 7 posts ] |
Users browsing this forum: No registered users and 65 guests |
