 Fuel Line Ideas
Post Fuel Line Ideas
Some ideas for the fuel line
In-Line Filter.
Allows view of fuel and dirt
Short version
See ebay
http://myworld.ebay.co.uk/jbimotorsport/
Small Inline Glass & Chrome Petrol Fuel Filter 8mm Carb
http://cgi.ebay.co.uk/Small-Inline-Glas ... 869wt_1139
In-Line Non Return Valve
Prevents fuel from draining from the pump.
Peter
See ebay
http://stores.ebay.co.uk/DISCOUNT-CAR-PRODUCTS
Fuel Non Return Check Valve one way petrol diesel 6mm
http://cgi.ebay.co.uk/Fuel-Non-Return-C ... _818wt_913
June 23rd, 2010, 3:02 pm
Post Re: Fuel Line Ideas
Both handy but it is advisable to take some pre-cut fuel line with you to bypass them if needed.
June 23rd, 2010, 3:29 pm
Based on the advice of others, I fitted my fuel filter BEFORE the fuel pump to prevent any crud getting into the gasket.
June 23rd, 2010, 3:41 pm
You mean where pete has his valve?
June 23rd, 2010, 3:42 pm
Erasmo wrote:
You mean where peter has his valve?
Yeh just forward
June 23rd, 2010, 3:53 pm
Could fit filter next to valve on the chassis for a road car.
However filter body is glass when removing/replacing the wing it could get damaged.
Part Two
Fit bowl type filter near the tank, if a can locate a small version.
June 23rd, 2010, 3:56 pm
i need to get a non return thanks pete :D
June 23rd, 2010, 3:58 pm
subarupete wrote:
In-Line Filter.
Short version
Yep, just like the plastic versions - which are also see-through - but more fragile and a damn sight more expensive. But blingier.
If the one in your pump already is buggered, then changing the pump might be a better bet. It could well have got damaged by unfiltered grot from the tank, though, so unless you put a filter before the pump, the next pump (or one-way valve...) may well go the same way.
Isn't there a filter on the outlet of the tank on the 4x4s, inside the chassis?
June 23rd, 2010, 4:24 pm
Why a non return? A mechanical pump can't function without its own internal non return valve.
June 23rd, 2010, 4:25 pm
over time it seems to get past it or evaporate but the time being two weeks im not sure?? but the fuel pump is dry
June 23rd, 2010, 4:43 pm
