View unanswered posts | View active topics It is currently April 29th, 2026, 2:38 am
Reply to topic  [ 7 posts ]
 Track rod removal tool
Post Track rod removal tool
anyone ever made one of these (or something similar to do the job) to save me shelling out £56.00
May 30th, 2010, 10:28 pm
Post Re: Track rod removal tool
2 hammers mate
or a tickle with the oxy set
May 30th, 2010, 10:41 pm
I usually undo the nut, leave it on the thread to protect it, gently lever the rod forward away from the rack (maybe with a bit of wood in there to stop your 4' crowbar doing damage) then give the nut a sharp clout, and it should come off the tapered bit.
May 30th, 2010, 11:34 pm
Simon,
I bought one of these:
http://cgi.ebay.co.uk/DRAPER-19MM-CAPAC ... 5882677c5a
i reckon it'll do the job, perhaps a small amount of fettling - i've yet to use it!
I can bung it in the post if you like.
May 30th, 2010, 11:42 pm
just to add to the confusion... :lol:
< http://www.tooled-up.com/Product.asp?PID=25695 >
£12.23 incl postage, needs a tickle with the angle grinder to fit in place.
Even then, you'll need to cut the anti-rattle rubber, though.
May 31st, 2010, 12:10 am
Thank you gentlemen, I might have a play in the garage today (today we need rain) then I will have a go at making one, if I don't succeed Neil I may take you up on your offer, although we should have one with us whilst racing.
Ken do we need to keep the rubber or can we just remove it and throw away?
Sean/Russ - I would normally use one of these methods, I need to use the gentle approach, as we want to too see if we have damaged the rack, so I don't want to add any extra forces/damage etc. etc.
May 31st, 2010, 9:12 am
used one of those fork things - it did the job :D
May 31st, 2010, 6:19 pm
