View unanswered posts | View active topics It is currently April 29th, 2026, 2:38 am
Reply to topic  [ 4 posts ]
 Play in engine.
Post Play in engine.
My spare engine has around 5mm of play somewhere in it. If I turn the flywheel, there's a noticeable clunk as (presumably) the timing gears mesh. Is this normal or is it a scrap engine?
May 26th, 2010, 1:16 pm
Post Re: Play in engine.
Open it :mrgreen:
May 26th, 2010, 1:17 pm
2CViking wrote:
Open it :mrgreen:
I've just put it back together ... :) I didn't check whether or not it was doing it before I took it apart. I suppose I'd better pull it apart again.
May 26th, 2010, 1:19 pm
There cant be any play at the cam gear as its split and has spring tension to eliminate any lash
more likley to be the crank
sometimes something gives a slight click when you turn it backwards, im guessing its the oil pump and the relief valve.
sean
May 26th, 2010, 10:01 pm
