View unanswered posts | View active topics It is currently April 29th, 2026, 1:31 am
Reply to topic  [ 10 posts ]
 Steering Rack Greasing
Post Steering Rack Greasing
What's the best way to grease the steering rack?
May 31st, 2010, 11:20 am
Post Re: Steering Rack Greasing
When its all apart?
Ken and Rick add a grease nipple to the cetral slider
you can reach in if you take the shocker plates off and add an extension to the grease gun or poke about with a stick
June 1st, 2010, 2:15 am
Thanks Sean,
I like the idea of adding a grease nipple
do I need to keep that anti-rattle rubber or can I throw it in the bin?
June 1st, 2010, 8:11 am
Simon Crook wrote:
Thanks Sean,
The nipple goes through the middle of the rubber.
June 1st, 2010, 9:38 am
Simon,
it's not just an 'anti-rattle' rubber, as it acts as a packer to eliminate any small amount of play in the rack's sliding bearing.
The older racks used springs instead of rubber.
Any fore and aft play at the inner end of the track rods will result in the road wheels having unwanted movement, toeing in on drive and toeing out on braking. :(
Simon Crook wrote:
Thanks Sean,
June 1st, 2010, 11:32 am
thanks Ken, another order for Ecas :D , Sean said about adding a grease nipple, is that an easy thing to do
June 1st, 2010, 11:35 am
most 4x4s have the added grease nipple
June 1st, 2010, 11:41 am
Any pictures? Does it need disassembling to fit?
June 1st, 2010, 2:19 pm
Joolz,
I fit grease nipples to both the steering pinion housing and the sliding bearing when rebuilding racks.
For the former, it's vital that the rack is disassembled, but for the latter, an M6 nut can be welded to the dust guard without fully dismantling the rack from the axle.
Obviously, the guard plate itself does have to be removed.
The anti-rattle rubber also needs to have a hole punched or drilled in it so that a 45 degree nipple can be screwed in.
Talking of which, I need to send one of those 45 degree items to Adrian for the guard plate which I modified recently... ;)
June 1st, 2010, 2:36 pm
<grin>
whilst Adrian needs to return the spare guard plate...
June 1st, 2010, 2:41 pm
Users browsing this forum: No registered users and 107 guests
