View unanswered posts | View active topics It is currently April 28th, 2026, 10:30 pm
Reply to topic  [ 4 posts ]
 Engine keeps on running!
Post Engine keeps on running!
Hi - got a bit of a strange one.
I've just put the blue car back together after it's chassis change. Connected everything up as per normal and fired it up. Runs fine and all electrics work apart from the fact that when you turn off the ignintion the engine keeps on running :? I've even removed the wires from the back of the ignintion barrel but this doesn't stop it either! I have to stall it or physically remove a coil connector to get it to conk out.
Before I set upon it with a meter and start checking the loom I was wondering if this could be caused by anything specific, or any tips on where to start looking.
Thanks!
Will
1979 2cv6 (Evie)
1983 Beachcomber (Mavis)
1991 AXGT Mk1
2008 C5 2.0 HDi VTR+
May 18th, 2010, 11:42 am
Post Re: Engine keeps on running!
Will,
has it got a loom with dim-dip?
If so, the diode could have failed and needs to be removed.
It's the black plastic item tie wrapped to the flasher unit.
Or, does it have a Visa type alternator, with built-in regulator?
If one of those is wired up as if it was a 'normal' 2CV type, they can cause this problem.
Thanks!
Will
May 18th, 2010, 11:51 am
Hi Ken
Thanks for the info. It does have the dim-dip so I will check this out. It also has a replacement alternator so I will check to see if it has a built-in reg.
Will
1979 2cv6 (Evie)
1991 AXGT Mk1
May 18th, 2010, 12:28 pm
Sorted! The alternator seems to have a built-in regulator and on disconnecting the original one - problem solved :D
Thanks!
1979 2cv6 (Evie)
1991 AXGT Mk1
May 18th, 2010, 10:34 pm
