View unanswered posts | View active topics It is currently April 29th, 2026, 3:59 am
Reply to topic  [ 7 posts ]
 Rev counter
Post Rev counter
Has anyone fitted a rev counter to their 2CV? Is it a tricky job? Or indeed possible?
Charlie is gone. Now 2CVless.
June 27th, 2010, 10:51 pm
Post Re: Rev counter
ECAS and 2CV stuff both supply rev counters.
Its harder than one might think to find one that will worth with one spark every 360 degrees but can be done, some harley davidson ones apparently work very well.
Its a topic that comes up from time to time if you have a quick search for more ideas.
June 27th, 2010, 10:57 pm
ok thanks. I keep thinking of a pod style one like street rods have :oops:
June 27th, 2010, 10:59 pm
i started a similar thread, or went off topic on one of mine onto this conversation,
i quite fancy one in mine..
June 27th, 2010, 11:27 pm
I have one which has been working for years. Bought it at 2cv.be, André Jacques.
June 27th, 2010, 11:58 pm
I see the ecas one is 80mm which I could put in a pod "hot rod" style and stick on the dash. Not sure if there is realy any point to see the 2CV rpm though, thinks it would look quite groovy.
June 28th, 2010, 12:10 am
Well, it helps you deal with too much acceleration which isn't good for the health of the engine as well as the environment...
June 28th, 2010, 9:21 pm
