View unanswered posts | View active topics It is currently April 28th, 2026, 10:31 pm
Reply to topic  [ 9 posts ]
 I think I'm missing some bits?
Post I think I'm missing some bits?
I've lost quite a few bits over the last few months. :roll:
At the bottom of the front wings there are two small holes - what goes there? Am I right in thinking a couple of those bonnet bump stop rubbers from the front bumper might be the answer?
And secondly, in the photo below (apart from the spring) what am I missing from inside the lamp adjust mechanism? I'm thinking there should be some sort of tubular spacer in there as the springs are too loose as it is now (hence one fell off which is now also lost) :?
April 23rd, 2010, 2:44 pm
Post Re: I think I'm missing some bits?
yes to the first, they are where the rubber bumper stops should go, not sure about the second bit as i dont have my car with me. sorry.
Joe
April 23rd, 2010, 3:15 pm
Yep a tubular-spacer-me-bob on the headlamp adjusty-thang.
April 23rd, 2010, 3:17 pm
In the past i have fit a roll pin cut to size for the spacer on headlight adjuster ;)
Low and Loud!
April 23rd, 2010, 3:53 pm
Thanks folks. I don't know where these bits disappear to, I've even lost two wheel nuts...I mean - how? :lol: The tubular do-da might not be so easy to find so perhaps I'll have to take a look at another one to see what size, length and width I'll need to cut. The lamp bar is causing me a few problems today due to it's not being sat right. :(
April 23rd, 2010, 4:19 pm
Old-Nail,
I seem to recall someone mentioning that one of the steel tubes which are moulded into a gearbox mount can be used as a direct replacement for a headlight adjuster spacer tube which has 'escaped'.
Mind you, not much good if you've binned that old gearbox mount... :(
April 23rd, 2010, 5:33 pm
I might still have that Ken, what a good idea! I did clean the garage out last week though what's the chances I threw it out? :lol:
April 23rd, 2010, 6:10 pm
You're best asking the person who drilled the holes what they're for. Probably bonnet clips of some kind.
I prefer the metal spring ones...
...to the nasty rubber ones.
April 23rd, 2010, 7:06 pm
Ooh!...Ahh!.....I thought the holes were there as standard....now there's a thing! I had toyed with the idea of some of these actually, but being leather they'd look like crap after a few weeks of weather I suppose.
April 23rd, 2010, 7:24 pm
