View unanswered posts | View active topics It is currently April 29th, 2026, 3:59 am
 MOT Time: What can I do to help get her through? SHE PASSED!
Post MOT Time: What can I do to help get her through? SHE PASSED!
As above really, grease king pins, take boot box off (it obscures rear number plate) bit of a clean..... what else?
Oh and is she likely to fail on:
The front fog lights STILL not being wired up
the floor at the forward edge of the passenger footwell being a little crunchy.
Cheers for any tips :-)
UPDATE: Cheers for the tips guys, she passed so tis all good :D
Last edited by samfieldhouse on April 16th, 2010, 6:21 pm, edited 1 time in total.
April 13th, 2010, 8:31 pm
Post Re: MOT Time: What can I do to help get her through?
A bribe?
April 13th, 2010, 8:32 pm
Ah Neil ya beat me!
A crisp £50 over the speedo ;)
Low and Loud!
April 13th, 2010, 8:40 pm
>shrug< make sure everything works like it should
:lol:
April 13th, 2010, 8:41 pm
Check all the lights ;)
April 13th, 2010, 8:50 pm
gym bunny
Front fogs dont matter... they wont even check them as not required, dont even think you need a spare wheel?! (might be wrong but the Fuzz dont carry them)
I never do anything really, dont even grease the pins. Quick check everything works or is tight before test then drop it in before work and collect with certificate after.
1299cc FTW
April 13th, 2010, 9:58 pm
If it obscures the plate, then you're liable to a tug from plod whilst out & about...
Nope, never testable. (Nor spare, Timmy)
Could easily be a problem, depending on how "crunchy".
Full tester's manual - http://www.motinfo.gov.uk/htdocs/m3i00000101.htm
If it ain't in there as a "reason for rejection", they can't fail it on it.
April 14th, 2010, 9:40 am
I've heard there is a "section" in the MOT manual, that is specifically aimed at the 2cv (identification of chassis rot) :shock:
April 14th, 2010, 10:41 am
If it's not there, it's not tested. If it is, then it is.
April 14th, 2010, 11:11 am
Depends who you take it to... You should see what mine and jonos tester passes... Im sure neil will tell you about my steering rack... :lol:
and apparently kingpins on 2cvs always have a lot of movement in them.
April 14th, 2010, 12:07 pm
