Page 1 of 1
[ 4 posts ] |
How much wheel bearing play is acceptable?
Rhythm Thief
I've just replaced the kingpin on the offside of my Charleston. While the hub was off the car, I noticed that I could move it around on the stub axle because of side to side play in the bearing. It moves maybe two or three mm and the play has disappeared now I've bolted the driveshaft back on. There's no play otherwise and the bearing is not noisy and seems in good nick. Should I be putting a new bearing in or is this normal?
| April 11th, 2010, 7:49 pm |
wiltz
 Re: How much wheel bearing play is acceptable?
sounds normal to me, I only change them when they sound dry and rough..
| April 11th, 2010, 8:04 pm |
Rhythm Thief
wiltz wrote: sounds normal to me, I only change them when they sound dry and rough.. That's what I was hoping to read.
| April 11th, 2010, 8:14 pm |
the big nut thats torqued to 35NM preloads the bearing
when its un done the 2 inner races move apart slightly( or fall apart if youve bought the cheapo ones from the cheapo shop)and so this allows the race to flop about
as long as it spins happily isnt gritty or noisy and there is little to no movement at the rim when the hub nut is done up, alls well
| April 11th, 2010, 10:31 pm |
Page 1 of 1
[ 4 posts ] |
Users browsing this forum: No registered users and 88 guests |
