View unanswered posts | View active topics It is currently November 19th, 2025, 8:32 pm
Reply to topic  [ 7 posts ]
 Organ accelerator pedal connections
Post Organ accelerator pedal connections
The time has come to attempt a connection for the accelerator pedal. When I got the car, there was no pedal, so I have nothing to work from in determining how to reconnect it.
I have the following bits:
Now - in this photo, we can see slightly better that I've got to attach the rubber bung to the pedal somehow. There's a tang inset on the pedal - do I push the rubber onto this?
Presumably it's the same for the hinge at the base?
Thanks! Ben
March 27th, 2010, 5:08 pm
Post Re: Organ accelerator pedal connections
It's been a while since i've had a car with this set-up; the larger plastic 'bearing' just presses into the bottom of the pedal, IIRC.
[useless trivia] the bearing used to cost £2.16 +vat back in 1998 & were available off the shelf from my friendly local Citroen dealer! [/useless trivia]
I got quite good at re-attaching the pedal to the floor bearing after it had 'slipped' off. Usually at the most inopportune moments!
March 27th, 2010, 5:20 pm
On my car the top rubber is clamped tightly by the sides and the tags, the bottom, as Neil says, is just pressed in.
March 27th, 2010, 5:22 pm
Thanks Neil and Russ.
Ah - I guess I need to bend the tags out and then bend them back to grab the rubbers.
I remember my dads aks400 used to pop the pedal off all the time too. What's more, I also remember going with him to a scrappy and getting a replacement pedal off a drum brake 2cv. Don't recall having to tour any scrapyards to find a 2cv in it. That was probably 1990 or so?
March 27th, 2010, 5:24 pm
I'll see if I can take a pic, give me 5
March 27th, 2010, 5:27 pm
Hope this clears it up.
looks slightly different to yours, but fitting appears to be the same.
HTH
March 27th, 2010, 5:51 pm
Perfect - thanks Russ! That is exactly what I needed to know.
I'll add that to the tally of cold beers I owe you :)
March 27th, 2010, 6:25 pm
