| VW Beetle 1500 pistons http://international2cvfriends.com/forum/viewtopic.php?f=7&t=1491 |
Page 1 of 3 |
| Author: | Rhythm Thief [ March 20th, 2010, 9:53 pm ] |
| Post subject: | VW Beetle 1500 pistons |
I'm toying with the idea of trying to mate a pair of VW 1500 pistons and barrels with a 2CV engine. Does anyone know if this will work, or is it up to me to pioneer this (and no doubt fail expensively Incidentally, I don't feel the need for more power particularly, but since when was a project like this about "need"? EDIT: Hmmmm, maybe I should have put this in "Technical". |
| Author: | Neil [ March 20th, 2010, 10:14 pm ] |
| Post subject: | Re: VW Beetle 1500 pistons |
moved! I posted this the other day in Harry's 652 thead: ![]() Quote: Antony from Bandung West Java sent these pictures of his 1985 FAF - he had recently rebuilt his 602cc 2CV engine by using the pistons/sleeves from a 1500cc VW to upgrade his egnine size to 750cc. Sounds like good ole Citroenist ingenuity to add a few horsies to this rare 2CV derivative. |
| Author: | Rhythm Thief [ March 20th, 2010, 10:28 pm ] |
That's where I nicked the idea from. |
| Author: | Neil [ March 20th, 2010, 10:29 pm ] |
Rhythm Thief wrote: That's where I nicked the idea from. |
| Author: | terpineol [ March 20th, 2010, 10:31 pm ] |
For anyone else who may be interested... http://www.vwheritage.com/vwh/VW-Beetle ... lateID=vwh |
| Author: | Rhythm Thief [ March 20th, 2010, 10:48 pm ] |
Wow. Less than £150 for four barrels and pistons. Cheaper than 2CV stuff |
| Author: | Joolz [ March 21st, 2010, 12:39 am ] |
Because I like maths Compare that to a 602 2 cylinder with a 70mm stoke which should have a 74mm bore, although I haven't double checked that with haynes. Incidentally, using 83mm pistons with the 2cv's 70mm stroke would give a capacity of 761cc. HTH |
| Author: | Rhythm Thief [ March 21st, 2010, 2:23 am ] |
Joolz wrote: Because I like maths Compare that to a 602 2 cylinder with a 70mm stoke which should have a 74mm bore, although I haven't double checked that with haynes. Incidentally, using 83mm pistons with the 2cv's 70mm stroke would give a capacity of 761cc. HTH You're absolutely right. I wonder how the chap in the link in Neil's post above managed to mate them to the crankcase? |
| Author: | Russell [ March 21st, 2010, 9:12 am ] |
I assume the crankcase is modified? I can't see it being a simple swap but I also wouldn't have though it'd be beyond the capabilities of a good machining firm. |
| Author: | Sean [ March 21st, 2010, 11:24 am ] |
I had a look at this years ago, there is also the issue of the gudgeon pin and deck height as well as the head head, studs and push rod tubes none of it impossible if you have a machine shop and too much time on your hands saw an engine once that used porche pistons think it was based on the visa, more meat on the barrel for increase in bore, but then you have to have the nickasil coating re done or have the barrel sleeved sean |
| Page 1 of 3 | All times are UTC + 1 hour [ DST ] |
