Reply to topic  [ 7 posts ]
 CPD Valve
Post CPD Valve
Im toying with the idea of fitting one of these CPD valves as im pretty sure my breather is totaly screwed has anyone fitted one of these valves and has it made any diffrence????
March 18th, 2010, 11:37 pm
Post Re: CPD Valve
yep and it works, it's just a cheaper and easier way to fix the problem ;)
Low and Loud!
March 18th, 2010, 11:42 pm
Post Re: CPD Valve
Does the engine run any better? What do you get? Better economy, or a bit more power?
March 18th, 2010, 11:56 pm
Post Re: CPD Valve
Maybe a few less drips of oil after a hard run? I'd like a verdict of how worthwhile it is also please.
March 19th, 2010, 5:30 pm
Post Re: CPD Valve
I have quite a bit of oil getting into the air clean which is why I ask as been led to believe that the breather being stuffed would do this!?
March 19th, 2010, 6:04 pm
Post Re: CPD Valve
Before replacing the oil breather, do a compression test to get a picture of how much compressed air is passing the piston rings. If compressed air hits the crank shaft housing (sump) even new original oil breathers can't cope with the pressurised air. It may be OK at low idle but not at high revs.
In other words it may not be the oil breather but too much pressure.
March 19th, 2010, 6:11 pm
Post Re: CPD Valve
Well, my 2cv has done 185,000+ miles (115,000 in my owership), on original, untouched engine, so I would hazard a guess that the rings are past their best.
March 19th, 2010, 6:30 pm
