Setting tappets WITHOUT removing inner / outer wings....
Willami
Joined: January 14th, 2009, 11:44 pm Posts: 501 Location: West Country, England
....can it be done?
more specifically to an Ami 6 - as getting the wings off is a right pain...
cheers
_________________ 1970 Volvo 144 (but i still like to see what's going on in A-Series land
| March 8th, 2010, 5:04 pm |
2CViking
 Re: Setting tappets WITHOUT removing inner / outer wings....
You need this tool to do it without removing the inner wing. I guess its possible but a pain. When you have the inner wing on the floor, modify it so next time you can unscrew the section in front on the valve cover to gain access.
| March 8th, 2010, 5:21 pm |
Willami
2CViking wrote: You need this tool to do it without removing the inner wing. I guess its possible but a pain. When you have the inner wing on the floor, modify it so next time you can unscrew the section in front on the valve cover to gain access. Thanks Viking - I can't even imagine how i'd use those tools - even if i had them - i'll take the wings off, i guess the more often i do it the quicker i will get.....i have seen whole front off in one go but always think that it would be bending everywhere.... cheers
| March 8th, 2010, 5:32 pm |
Russell
On mine it's actually a challenge to get the rocker boxes off without taking the wings off, and I've certainly never done it without dropping the oil everywhere. I am thinking of making some plates which bolt over a hole I'll cut into the inners next time I change the engine. If you can find a half decent set of ami inner wings I'll modify them for you to suit.
| March 8th, 2010, 8:04 pm |
Willami
Russell wrote: On mine it's actually a challenge to get the rocker boxes off without taking the wings off, and I've certainly never done it without dropping the oil everywhere. I am thinking of making some plates which bolt over a hole I'll cut into the inners next time I change the engine. If you can find a half decent set of ami inner wings I'll modify them for you to suit. sounds like a good idea.. i'll see how i get on but thanks for the offer. inner wings seem to be the hardest thing to get a nice set of... p.s - i bought a rear door for mine off ebay recently - turns out the gutter depth and captive nuts for the frame are different for a Berline - f**k!!!! that's what i bought....didn't think to check...another lesson learned know anyone who needs a Berline rear door!!! cheers Will
| March 8th, 2010, 10:09 pm |
EirikJ
Quote: p.s - i bought a rear door for mine off ebay recently - turns out the gutter depth and captive nuts for the frame are different for a Berline - f**k!!!! that's what i bought....didn't think to check...another lesson learned Really? Good to know, thx!
| March 8th, 2010, 10:26 pm |
Russell
Yeah, I'm very suprised to hear that, I'd assumed they were all the same!
| March 8th, 2010, 10:37 pm |
Willami
Russell wrote: Yeah, I'm very suprised to hear that, I'd assumed they were all the same! well i'd better check for certain before flogging it.... instead of slots in the gutter for taking the drips, they are 5mm holes and the gutter itself sits alot deeper. To start with I thought it might have been off a really early model - but IIRC the early ones didn't have sliding rear window????? Matt???? where are you??? cheers now
| March 9th, 2010, 12:41 pm |
2CViking
Join the club. I found out the same way when I wanted to move over the rotten window seals from scrap Ami 6 to our daily runner (Ami 6 1967). The Ami 6 before 1968 is not the same as after. The Ami 6 from 1968 onwards and Ami 8 do share the same doors. The clues are engine design, speedo pedal, alu trim around the doors
| March 9th, 2010, 2:50 pm |
Willami
2CViking wrote: Join the club. I found out the same way when I wanted to move over the rotten window seals from scrap Ami 6 to our daily runner (Ami 6 1967). The Ami 6 before 1968 is not the same as after. The Ami 6 from 1968 onwards and Ami 8 do share the same doors. The clues are engine design, speedo pedal, alu trim around the doors
Hi Viking - well the plot thickens. I will take some photos of the spare door I now have. The captive nuts(for the aluminium frame) are set alot higher on this replacement, and the bare metal gutter is a good 30mm deep. I've stripped the FRONT door sills on mine and they are probably only 20mm. Haven't actually stripped the existing rear door on mine to line up the replacement yet - but i'm 90% certain that my existing black nylon 'cover' will fall down into this new door and besides - the glass will not fit as the frame is attached will be too high. Jerome's brilliant site may hold the answer - they did chop and change the doors a bit - there was that mid period when they had the Axo lights & steel roof but with Ali door frames???? overlaps!!!! cheers now Will
| March 9th, 2010, 3:28 pm |
Users browsing this forum: No registered users and 94 guests |
